Minnesota to try and ban gas powered equipment
Status
Not open for further replies.
   / Minnesota to try and ban gas powered equipment
You could smell and taste the oil and fuel in the ocean but sunscreen is the problem??
Remember when the Olympics were in China? The factories were shut down (for a month or so) so the air pollution would "go away" and allow the TV cameras to show a squeaky clean country? Otherwise, the smog is so bad they can't go out and breath the air without masks (which aren't good enough anyway). Hypocrites!!!
Same here. Entire industrial parks being built on some of the best farmland around.
Whatever happened to that big TV production factory that was going to go up in your SE WI area, that got all sorts of govm't $? Did it get built?
   / Minnesota to try and ban gas powered equipment #295
So they are plugin tools powered off a solar system storage made from......batteries.
No. The solar farms feed the grid. The factories use power from the grid. There are some huge solar farms going up in Indiana, something I never expected, especially northwest Indiana, with it's permacloud from Lake Michigan.
   / Minnesota to try and ban gas powered equipment #296
   / Minnesota to try and ban gas powered equipment #297
They're still trying to land a $2.4B vehicle battery plant here.
If they don't attach themselves or seal good to the filler neck, IF there is any suction going on, it won't be sucking the fumes - only air.
I just came back from a weekend in/around Chicago. No "vapor collecting" gas station hoses connections there, that I saw...
   / Minnesota to try and ban gas powered equipment #299
To put it in perspective for those that won't read the article...
how much of America’s 900 million arable acres are owned by Chinese nationals?
Chinese entities own 0.04 of 1 percent of total U.S. farmland.
   / Minnesota to try and ban gas powered equipment #300
Status
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
BUNDLE OF 6" X 12" BUILDING PURLIN (A54757)
BUNDLE OF 6" X 12"...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
Towable spreader (A55973)
Towable spreader...
2017 Ford F-350 Ext. Cab Pickup Truck (A56858)
2017 Ford F-350...
