Minnesota Pull behind tool towing question?
   / Minnesota Pull behind tool towing question?
M parked at a gas station that has lots of officers there to see if anyone says anything.
   / Minnesota Pull behind tool towing question? #22
Ob u didnt read posts. They are not trailers and i have a class a 2 and 3 and t end valid for all combinations
I read it. Why do you believe they are not "trailers"? They have their own structure and are intended to be towed by a motor vehicle. They are trailers. If they are not registered "trailers" then I doubt they are legal to be pulled on the public road. On your own land yes, but not on the road. If you are pulling them for your own farm, there are a lot of exceptions. For hire on other peoples farms and I think you lose all the ag exceptions as you are probably considered a commercial vehicle. Nothing in this state (Minnesota) that moves is allowed on public lands and waters without being licensed and tax (except by bicycles for some reason), and that includes trailers even my arm powered canoe.
https://www.revisor.mn.gov/statutes/?id=168.002
If you have a class A valid for combos I doubt it would be illegal.
Depending on your speeds, I would be worried about stopping. Does at least one of them have brakes? Make that your first trailer. If you don't have brakes on either, decide how you are going to safely control and stop them.
In the eyes of the legislature They clearly are not "semi trailers" and one isn't a recreational vehicle, so if the lengths and weights are under the combination limits you don't meet the requirements to need a permit and I don't see it as specifically illegal. If you are rural I doubt anyone will bat an eye. If you are in the metro area, be prepared for state police commercial vehicle surprise inspections (they hide behind the bushes on the on ramp to I494 all the time by my house) and being able to argue why it is not illegal. They will make you leave one on the side of the road if they determine you are illegal. I see them offloading overweight and leaving trailers all the time from these inspections. If you are doing it for hire, I would make sure you have your "trailers" legally licensed. If they don't have vin's, then look up the licensing procedure for "home made trailers" in Minnesota.
The law says they are not trailers. They define as pull behind tools. 168.012 sub div 5. Read it. And why would u need brakes on less then 800lbs.
The law says they are not trailers. They define as pull behind tools. 168.012 sub div 5. Read it. And why would u need brakes on less then 800lbs. And you said "fairly sure you need CDL with "doubles" - - REGARDLESS of it all being under 26K." So i assumed since i mentioned i had a cdl prior, that u didnt read posts. And i never claim an ag ex
   / Minnesota Pull behind tool towing question? #25
We do it all the time. MDOT does it all the time, Look at the sign trailers they use We hook multiple reel trailers to each other and go. This is short trip stuff from job yard to site less than 10 miles. I have seen 4 grain wagons behind a tractor once, they actually tracked fairly well
   / Minnesota Pull behind tool towing question? #26
168.012 sub div 5 has to do with registration. They still need lights, tail/stop and turn. There are special exemptions for farmers and a RV exemption that allows certain combinations. The combination you want to pull would not be allowed.
I would suggest you call the commercial vehicle section of the MN State Patrol. Most of the road troops and city cops do not deal with anything commercial on a regular basis and would call the commercial vehicle section anytime they run into something unusual.
So the answer to your question is it is not a legal combination. I am pretty sure the minimum citation is around $135 when you add in court cost.
  • TR_RV_BoatTrailers.pdf
   / Minnesota Pull behind tool towing question? #27
Then i wouldnt be saving fuel. Trailers weigh. And then i have to empty out 5 gal of gas from compressor to put on trailer. And to be legal id have to install ball hitchs on trailer and no. I couldnt use it to haul otherstuff. Not even gasoline for compressor. And im sure trailer have sinkin issues in peoples farm fields in sringtime
You would not have to empty the gasoline out of your compressor and you can haul gas for your compressor in a can as long as it is a proper gas can and is secured.
Brakes are only required on trailers rated at 3,000 #s or more.
If the total combined weight is over 10,000 lbs gvwr or actual you will also need a DOT # and have to adhere to all DOT regulations.
I don't understand your statement about having to install ball hitches on the trailer, could you clarify?
   / Minnesota Pull behind tool towing question? #28
As long as you have lights on them I wouldn't worry about it
They all light up. And I guess you cannot understand that they are not trailers. If they were they would need to be licensed. Ive asked and everyone local says its legal or unknown because they are tools and not trailers. A trailer carries stuff. And these do not. Only their bolted together parts by their seperate manufactures. Ans i scaled out van and tools and total weght is 1250 van stear, 3000 rear drive. Tool 1 axle is 175 and tool 2 is 150. So im nice and light. And last night every cop looked at it and radioed for a few mins and only comment I got was one said "nice tools!" So I am going to roll with it untill a judge says not to. Thanks for all the imput.
And by ball hitchs installed thats the quick easyway th trailer something with a hitch. On the flat bed u put an I beam 1ft high and weld a ball hitch on it. Then u roll trailer or tool on flat bed and hook hitch and add one chain to axle. Then its more then safe. And you only had to use one chain. Not 2 or more
2013 Peterbilt 367 QMC 7060S 35 Ton Tri Axle All-Terrain Crane Truck (A55973)
2013 Peterbilt 367...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
LOT: (17 approx. ) Chain Link Fence Panels (A59076)
LOT: (17 approx. )...
2022 Horizon Trailers DH8BP-2 15ft 5 Ton T/A Dump Trailer (A55973)
2022 Horizon...
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
