Minneapolis Moline RTU with wide front end??
   / Minneapolis Moline RTU with wide front end?? #11
That part of the tractor could have been pulled from a used RTU since it clearly looks like a RTI version.
I figured they put a heavy RTI front end under a RTU.
Since the serial number does not match what is in the photo where is the serial number located on the tractor? That part of the tractor could have been pulled from a used RTU since it clearly looks like a RTI version.
Good point, the serial number plate is attached to the side of the tranny it looks like so it may be that they pulled a tranny from an RTU somewhere along the line but it looks like an RTI. The front end sure looks like the RTI as it is pretty heavy duty. The loader is a Reese rated at 2500 lbs which seems pretty stout for that size of a tractor but I don't really know because I am truly a newbie...
Thanks for the info I will see if there are any markings on the frame that would confirm your suspicions.
   / Minneapolis Moline RTU with wide front end?? #13
You will need to do some measuring to ascertain if you have an industry standard three-point hitch.
With production years of 1940 - 1953 hitch may be industry standard or it may be non-standard/proprietary to MM.
ANYONE OUT THERE FAMILIAR WITH THE HITCH SYSTEM ON THIS TRACTOR?
FERGUSON 3-PT HITCH DIMENSIONS REFERENCE THREAD:
http://www.tractordata.com/articles/technical/threepoint.html
Have you looked at this T-B-N thread?
http://www.tractorbynet.com/forums/all-other-brands/168099-old-minneapolis-moline-rti.html
Thanks for all of the info but I think it is just as it is supposed to be. I found a couple of resources that have lists of numbers and it wasn't until 1948 that the RT(X) designations really came into affect. For instance here is an example:
http://jetstar.minneapolis-moline.com/MM-Louis_serials.txt
RT TRACTORS
1944 409358 - 410757 inc.
1945 410748 - 413754 inc.
1946 413755 - 416544 inc.
1947 416545 - 422057 inc.
1948 (RTU) 0014800001 - 0014802402 inc.
1949 (RTU) 0014900001 - 0014903039 inc.
1950 (RTU) 0015000001 - 0015002155 inc.
1951 (RTU) 00102156 - 00103972 inc.
1952 (RTU) 00103973 - 00104823 inc.
This list does not call out RTU specifically until 1948 when the serial number sequence changes. Mine fits into the 1947 row before the 00 was added to the serial number. On another list:
The Model "R" Series M-M Registry List
There is a comment that the RTU from 1947 (serial number listed is one later than mine) that it has a wide front end.
RTU 421507 U Has wide front end
So I guess the answer is that this is an original 1947 RTU but not really considered the RTU yet... Best I can figure...
   / Minneapolis Moline RTU with wide front end?? #15
I think you have a beauty!
   / Minneapolis Moline RTU with wide front end?? #16
That is great it is stock.
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
Case IH Farmall 105C Tractor (A50514)
Case IH Farmall...
RING 3 STARTS HERE @ 9:30 AM (A51244)
RING 3 STARTS HERE...
2017 GEHL RS5-19 TELEHANDLER (A51242)
2017 GEHL RS5-19...
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
