Minneapolis Moline RTU with wide front end??
   / Minneapolis Moline RTU with wide front end?? #1
rdhaley1
Kuna, ID
Hi all I just got my hands on an old MM, first time tractor owner, and I am going to need some help while I learn all about it. Figuring out what model of tractor is a good start so I am hoping someone can help me with that.
The nameplate on the tractor says RTU with ser#421056U. It looks like some of the pictures but everything I can find says that the RTU model is a narrow front end where this one has a wide front end.
Is there a model of RTU that does not have a narrow front end?
   / Minneapolis Moline RTU with wide front end?? #2
Hello, how about some pictures?
Here is what it looks like, the bucket hardware kind of hides the details of the side and the hydraulic tank covers the front end so its hard to get a good read on it.
Also I can't get a good picture of the info plate because there is a metal bracket right in front of it but it definitely says RTU #421056U
   / Minneapolis Moline RTU with wide front end?? #4
Looks like it has a standard front end and with the low profile it could be an Industrial version of the RTU.:confused:
   / Minneapolis Moline RTU with wide front end?? #5
Industrial yes, that's what I was thinking, RTI.
Like this.
The other wide front ends look like coffee straws compared to this one. I personally think its the only one that would support the extra weight of a loader.
The only problem is I don't think the serial number matches to an RTI.
   / Minneapolis Moline RTU with wide front end?? #8
That looks a lot like mine. Tractor Data says the RTI has a foot throttle and clutch which mine has. I will do some more looking and see what else I can find.
   / Minneapolis Moline RTU with wide front end?? #10
Since the serial number does not match what is in the photo where is the serial number located on the tractor? That part of the tractor could have been pulled from a used RTU since it clearly looks like a RTI version.
2015 Chevrolet Impala Limited Sedan (A42744)
2015 Chevrolet...
2016 Toyota Camry Sedan (A42744)
2016 Toyota Camry...
2010 Lincoln MKS Sedan (A42744)
2010 Lincoln MKS...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A43003)
2019 KENWORTH T680...
CAT 561C (A45046)
CAT 561C (A45046)
2012 FREIGHTLINER  CASCADIA (INOPERABLE) (A45046)
2012 FREIGHTLINER...
