Minneapolis Moline 445 Hyd trouble
   / Minneapolis Moline 445 Hyd trouble #1
racekar18
MM 445
My 445 is having serious hyd trouble. The pump gets to hot to touch after only 30 seconds. I had the pump rebuilt and the pressure relief valve was completely melted. After installing the pump it still gets hot. Also the pto turns all the time. Mabye a related problem? Any help please?
   / Minneapolis Moline 445 Hyd trouble #2
My only MM experience is with a M5 (and not much at that). What did you do about the "melted relief valve"? Sounds to me like the pump is deadheaded for some reason and the oil was going past the relief valve causing the heating problem. I would make sure all valves are in neutral. The M5 has very little hydraulic oil capacity and expect yours is the same, so it wouldn't take much to build heat fast. I don't think the M5 even had a relief valve, or least not an obvious one. I don't recall anything on the PTO operation.
If no one here can help, try on YesterdaysTractors.com.
Kim
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A54313)
2017 FREIGHTLINER...
PENDING SELLER CONFIRMATIONS (A54313)
PENDING SELLER...
2012 International Vactor Sewer Truck (A52377)
2012 International...
Hose Reel (A53424)
Hose Reel (A53424)
Light Tower (A52377)
