Minneapolis Moline 445 Hyd trouble
   / Minneapolis Moline 445 Hyd trouble #1
racekar18
MM 445
My 445 is having serious hyd trouble. The pump gets to hot to touch after only 30 seconds. I had the pump rebuilt and the pressure relief valve was completely melted. After installing the pump it still gets hot. Also the pto turns all the time. Mabye a related problem? Any help please?
   / Minneapolis Moline 445 Hyd trouble #2
My only MM experience is with a M5 (and not much at that). What did you do about the "melted relief valve"? Sounds to me like the pump is deadheaded for some reason and the oil was going past the relief valve causing the heating problem. I would make sure all valves are in neutral. The M5 has very little hydraulic oil capacity and expect yours is the same, so it wouldn't take much to build heat fast. I don't think the M5 even had a relief valve, or least not an obvious one. I don't recall anything on the PTO operation.
If no one here can help, try on YesterdaysTractors.com.
Kim
2018 DODGE RAM 3500 LARAMIE SERVICE TRUCK (A51406)
2018 DODGE RAM...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2019 TRITON TRAILER ALLMAND MAXI LITE 45 GENERATOR (A53843)
2019 TRITON...
40ft Shipping Container (A52377)
40ft Shipping...
2016 VOLVO VNL SLEEPER (A54313)
2016 VOLVO VNL...
