Minimum Pitch for Metal Ribbed Roof
   / Minimum Pitch for Metal Ribbed Roof #31
You also ignore what the manufacturer recommends. :confused3:
Manufacturer recommendations are full of hidden lawyer speak. They're all about potential liability to the manufacturer. 'If you don't do it this way, you can't hold us accountable, yadda-dada, yadda-dada, yadda-dada......' It doesn't mean that is the ONLY way to do it. Humans regularly tweak those recommendations without incident. You can do it different and still be safe if you design for your particular application, which is what we're advising the OP based on our own experiences.
   / Minimum Pitch for Metal Ribbed Roof #32
The OP says they will be using "ribbed style metal roof"...exactly what style? one of the most common is "5V"...
There are many different configurations especially for commercial / industrial applications...
One of the most common low pitch commercial roofs are seen on rental storage unit buildings...some have hardly any pitch at all yet but making sure rental client properties are kept dry would be paramount to a storage business...
Most of the roof systems that come with storage building roofing packages include ribbon calking and both hold down and stitch screws...
   / Minimum Pitch for Metal Ribbed Roof #33
Snow load just use more framing and move slates closer. The problem is going to be where the roof meets the wall above window and soffit area. Rain is going to keep that soffit wet from splashing. They are not designed to get wet and debris will build up in that crevasse you create. Both soffits need to be non vented vinyl. Where the tin meets the vinyl siding the whole area above that valley behind vinyl needs to have water barrier and return splash to the tin roof. Also on bottom edge of the vinyl a notch will need to be cut to keep the water from traveling the length. Vinyl is far from water proof when rain isn't falling straight down. Plus I think the roof line will look terrible.
You all bring up valid points. Here is how I am looking it. I can buy a gazebo or canopy and put it over the porch, but the gazebo's are expensive and the roof of the gazebo would slant in all 4 directions which when it rains, it would slant towards the door and the rain would hit the door. The canopy would more or less do the same thing, so my thoughts is that it would be more cost effective to built a slant roof. I could make it the size that I need and it would look nicer and be more stable. As RoyKing mentioned, wetness and debris could collect between the eave and the roof which is a good point, but I could use trim coil that is the same color of the gutters and flash it behind the gutter and slope towards the new roof. /Pine, the roof panels I am looking at are at Home Depot.
https://www.homedepot.com/p/Metal-Sales-8-ft-Classic-Rib-Steel-Roof-Panel-in-Charcoal-2313217/204254778
   / Minimum Pitch for Metal Ribbed Roof #35
I recommend NOT buying them at any Big Box store where they can be $3.00 per linear foot or more.. Check roofing suppliers or lumberyards. Prices I just got are around $2.25 per linear foot. You can also get custom lengths that way, 8'6", 9' or whatever you want. Most don't stock any at all, but delivery is usually within 2-3 days.
   / Minimum Pitch for Metal Ribbed Roof #36
You should be fine doing what you want to do and as far as manufactures specs they also tell you not to fasten tin in the ridge but people have been doing it successfully for more than 50 years, leak free.
   / Minimum Pitch for Metal Ribbed Roof #37
ABC Metal Roofing makes a PBR profile that is rated to 1/2:12 pitch. The ribs are 1-1/4" tall and 12" OC. PBR | ABC
We are getting ready to replace the standard Imperial Rib (3:12 rated) panels on our 2.5:12 pitch shop roof.
   / Minimum Pitch for Metal Ribbed Roof #38
Tuftex translucent panel installation instructions specify a minimum of one inch rise per foot, or 3” per foot in heavy snow areas. At that low of a pitch, you do need to seal the overlaps to prevent leaks between the panels.
I covered my pergola 4 years ago with 16’ Tuftex panels installed at just over the 1” per foot minimum. It has held up great and has had 8” of snow several times with no problems and no leaks.
The wind is favorable here so water is never blown up the pitch of the roof, but in my installation, it wouldn’t matter if it did.
   / Minimum Pitch for Metal Ribbed Roof #39
I don't think anyone here is shouting "The Sky is Falling". Just many varying opinions and suggestions.
And you are free to ignore what he does. :)
   / Minimum Pitch for Metal Ribbed Roof #40
I agree on taping or caulking the overlap. I had 1/12 sheds added onto both sides of a sixty foot long barn with up to about 16 inches of wet heavy snow on it. Perhaps it was due to having animals within but after snow events like that I would get minor enough ice damming on the one foot overhang outside of the walls. Then during a melt, water would pour out of the seams.
Yep, animals will put out a surprising amount of heat.
I agree. Get them precut to the right length for the roof (no horizontal joints that way), put down silicone calk on the seams and make sure you flash it properly where it meets the wall/eave.
Aaron Z
2011 Ford Edge AWD SUV (A55758)
2011 Ford Edge AWD...
Metal Rooster Statue (A55758)
Metal Rooster...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2018 JLG 3246ES 32ft Electric Scissor Lift (A53421)
2018 JLG 3246ES...
