Minihoe and Oscillation
/ Minihoe and Oscillation #1
Sedgewood
Platinum Member
Columbia Co, Eastern NY
PT-1845
When one applies enough down force with the minihoe to lift the front of the tractor off the ground the front section immediately flops to one side (PT pucker II?). I got thinking about how one could add some kind of stabilizers. Then I got to thinking some kind of oscillation lockout might work, maybe a big plate that would bolt to one section and ride under the other such that the tractor could articulate but not oscillate. When I took a look at the tractor the solution seemed obvious and much simpler - a pair of blocks either side of the upper arm to add a more restrictive oscillation limit. Maybe leaving just a bit of play for a bit of oscillation. Think that would work? Instead of oscillating into PT pucker II would the whole tractor just fall over (PT pucker III)? /forums/images/graemlins/shocked.gif
Sedgewood
/ Minihoe and Oscillation #2
<font color="blue"> When one applies enough down force with the minihoe to lift the front of the tractor off the ground the front section immediately flops to one side (PT pucker II?) </font>
Alternate solution: <font color="red"> Don't do that. </font> /forums/images/graemlins/cool.gif
/ Minihoe and Oscillation #3
One solution: Counterbalance by increasing operator weight! Wait, I'm already doing that...
-Rob /forums/images/graemlins/blush.gif /forums/images/graemlins/tongue.gif
/ Minihoe and Oscillation #4
<font color="blue"> Counterbalance by increasing operator weight! </font>
Good idea! I hit 210 last weekend after a loosing battle with Hungarian pastry. /forums/images/graemlins/blush.gif
