mini welding table
/ mini welding table #51
I looked at that vise today at HF. Man they have a heck of a selection over there.
/ mini welding table #52
Most used welding table clamp is a modified bar clamp that uses a 5/8” bolt to table top. Can be used as regular clamp or spreader still. Secures 4” machinists vise horizontally or vertically to the table as needed. Good ground thru the table.
Many attachments for holding options.
OK, here is one with Mr vice attached. What you can not see is the square tube for the vice plate is mounted 2" off of center. It that called non-concentric? What-ever-the-case, you can reverse it and the vice will then be over the edge by 2".
2011 Ford Ranger Ext. Cab Pickup Truck (A59230)
2011 Ford Ranger...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
Cushman Electric Cart (A55851)
Cushman Electric...
2022 John Deere 5055E (A60462)
2022 John Deere...
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
