Mini split A/C Heat Pump systems
   / Mini split A/C Heat Pump systems #41
I did get a quick response from John at Chiltrix.
Bottom line is that it is very expensive, at least for me. Basically a little over $9k. I can get the "same thing" in a pioneer for $3600.
I'm certain I can buy many extra feet of tubing and get an HVAC guy to sign off my install for $5,500.
Pity too, I liked the technology.
   / Mini split A/C Heat Pump systems #42
It certainly isn't the cheap option, but it for us it is cheaper than going Geothermal and our floorplan isn't very friendly to ductwork, and I hate ductwork.
   / Mini split A/C Heat Pump systems #43
Agreed. I guess I don't see the benefit of it over a mini-split (where "freon" goes to the rooms instead of super-cooled water/glycol).
I suppose "just" efficiency. For me, using it a month or two a year, efficiency is only of some concern. Either system is way better than a window unit, I'm sure.
So that's what started this. No point in spending $400 for a window unit this summer if we're gonna be able to do a mini-split next summer.
   / Mini split A/C Heat Pump systems #44
A little different climate for us, our A/C runs as early as March and as late as November most years with triple digit temps for a few months. In your case, the mini split is a near perfect solution. A/C is our largest electrical consumer, by a large margin, so the most efficiency we can get is all savings. That was why were thinking Geothermal but in our area it is cost prohibitive for us.
   / Mini split A/C Heat Pump systems #45
In a perfect world (and I think a chiller might be perfect for this) I would use the extra AC heat to dump into my heat storage tank. Then I'd take a shower with it. =) The heat gain vs. the cost to do it isn't justifiable though.
   / Mini split A/C Heat Pump systems #46
We went with LP on demand hot water or we have used a Heat Recovery Unit to a tank, but the on demand has worked beautifully and used very little propane since January.
   / Mini split A/C Heat Pump systems #47
for heat, I have an HS Tarm wood-fired boiler with re-burner (gets hot enough to burn exhaust gasses) attached to a 1600 gallon reserve tank. Then radiant floor heat. It's slow recovery, but very nice overall. Hot water comes from a coil within the tank (effectively a 1600 gallon water heater).
   / Mini split A/C Heat Pump systems #48
Just got our quote for our mini split
1- Fujitsu 24,000 BTU Mini-Split heatpump Outdoor Unit Multi-zone
1-9,000 Indoor Unit
2-7,000 Indoor Units
3-Remote Controls
Disconnect
Pad
Whip
Line Sets
$6800
   / Mini split A/C Heat Pump systems #49
On highseer.com
3-zone (27000 BTU) - $1155
3ea 9,000 BTU wall-hanging unit - $198ea.
$1749.
So you'd have to figure out disconnect/pad/whip/line sets. (what is whip?)
I'm trying to quantify line sets. I watched on TV (and youtube) TOH install one and they just used flexible copper line, doing their own flares. I know how to do that, and have plenty of times before. As such, I see no need to buy their super high-dollar line kits (that won't be the right length anyway). Unless I'm wrong, of course.
   / Mini split A/C Heat Pump systems #50
Whip is the electrical cord components.
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
Animal Service Truck Bed (A49461)
Animal Service...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2008 FREIGHTLINER FLD120 SD DAYCAB (A50854)
2008 FREIGHTLINER...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
