Mini skidsteer
/ Mini skidsteer #1
jcscat
Phoenix,az
bobcats, caterpillars
Have a Powerhouse pro mini skidsteer, it has no power to make a turn
like low pressure. any ideas. where to look up parts online
/ Mini skidsteer #2
Does either side have power? I'm pretty sure skid steers use separate pumps per side. Is that the case here?
/ Mini skidsteer #3
I am not familiar with your machine but I would start with the basics. I assume you've checked fluid level. Do both wheel motors appear weak and how are the other hydraulics functioning ( is it only the drive or is the FEL weak too)? A good place to start is to plumb a gauge into hyd. system and see if it is the pump. If you have good pressure, start looking for bypassing relief valves, worn wheel motors etc. I found a parts manual online, a service manual would be nice but parts diagrams can be very helpful in identifying exactly what part is what and location, etc. https://shop.morbark.com/documents/boxermanuals/Power House Prowler.pdf
/ Mini skidsteer
Low power on both sides of the drive. Replaced one drive motor a few years ago. Lift capacity seems fine. Has 2 drive motors and a chain
from the front tires to the rear tires. Seems like a old machine from Home Depot they use to rent.
Thank you for your help, really appreciate it
Have a Blessed day
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
New/Unused Electric Winch (A65583)
New/Unused...
(16) Trimble True Count Clutches (A65640)
(16) Trimble True...
Kubota M4700 (A64126)
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
