Mini Grader
/ Mini Grader #1
dullpain
Platinum Member
Middle Tennessee
Kubota M5700 4 WD w/ FEL, Kioti CK4010SE HST, 21' Flatbed Gooseneck Trlr.
I have seen many people in different forums discuss grading long driveways, wishing to make road beds, access roads, prepare pads for barn construction, etc.
I ran across this ad in one of the farm publications I receive. It looks interesting so I thought I would share with all.
I know nothing of the company or how well this grader works / or doesn't work. I'm sure if anybody out there owns or uses one like it we all will hear about it.
/ Mini Grader #2
I have seen these in a larger scale used for leveling field in the central valley of California. It always struck me that for a smaller scale such as pictured that one could make one fairly inexpensively if they own a longish trailer and a blade.
/ Mini Grader #3
Gearmore is now selling a similar product called a "Drag Scraper." It looks like a box scraper, without scarifiers, pulled by a long tow bar with support wheels trailing. Most have a hydraulic piston raise or lower the box. Stated purposes vary from roads to dairy/feed lot scraping, material moving. From 5 to 12 feet wide, from 500 to 2000 lbs. JonB
/ Mini Grader #4
Looks a little like the pull behind graders that were used by the state and local highway departments when I was growing up in the 1950's. These were towed by dump trucks and had a place for a man to stand and adjust the blade (with manual controls) You still see them occasionally on privrately owned camp roads. No reason why it shouldn't work o.k.
/ Mini Grader #5
I've seen these work and if the material is loose they work really well but it you have any kind of hard packed dirt they don't do anything. You also have to have alot of room to work them in and they don't work well for small places. Also they take a long time to work if you are doing small place. In my opinion they're just overpriced rear blades.
Richard
/ Mini Grader #6
Interesting, I never saw one of these before your post, although I've heard them described. So today I see one like this only larger and with dual wheels being pulled by a tractor.
I couldn't really tell but it looked like a massey in the 90-100 class. He was blading a dirt road. I went back later when I had more time, to get a closer look but it was gone. The road he had been working on looked pretty darn good.
Ernie
"I go whole hog in the cause for Texas"
Micajah Autry Jan. 1836 (in a letter to his wife)
/ Mini Grader #7
I've only seen the pictures of that grader, but I have a neighbor who has an 11' box blade with hydraulically controlled gauge wheels (full size car tires). It's pulled by the drawbar, not the 3-point, he can raise it high enough to pull down the road or lower it until he lifts both wheels clear of the ground. I've watched him work with it and it's sure a fine rig. Of course he's pulling it behind a 120hp Deere. He and I built the parking lot for the new fire station a couple of years ago. He did about 95% of it with his big rig and I did the work in the tight spots with my little B7100 and 4' box blade./w3tcompact/icons/laugh.gif
Bird
2023 Case 75c FarmAll Tractor (A62679)
2023 Case 75c...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
Wolverine MCB-11-48W Mini Skid Steer Bucket (A62679)
Wolverine...
1990 FRUEHAUF 53' DRY VAN TRAILER (A65054)
1990 FRUEHAUF 53'...
Bombarder Sea Doo GTI (A64127)
Bombarder Sea Doo...
(INOP) 2022 MACK MD6 WATER TRUCK (A65054)
(INOP) 2022 MACK...
