Buying Advice Mini Excavators
/ Mini Excavators #11
Tracks to the wall 🍻
/ Mini Excavators #12
… also some models that offer convertible controls* that can replicate tractor like digging controls. …
*saves learning times and helps safety by preventing false moves under pressure.
Most makes and models made in the last 20 years have either a manual valve or an electronic valve that changes from backhoe to excavator controls. Some (mainly older) models may require switching a couple of hoses.
/ Mini Excavators
Can you define “right up next” to the foundation? 1 inch? 6 inches?
How much room do you have behind the foundation? I can dig about 3 inches from a foundation with my backhoe, provided there isn’t anything behind it (for the rest of the tractor to hit).
You wont need a mini-ex to dump, just come in at say a 30 degree angle, leaving 60 degrees to dump. Unless I am missing the setup.
Close enough to not require "a lot" of hand shovel work to get a look at the foundation. That is not an actual requirement I guess, need to get close to the footing to lay stone and pipe.
The BH may be able to do the job, coming at an angle as suggested. Probably the best thing, money wise.
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
Lot of 4 12-16.5N.H.S. Skid Steer Wheels and Tires (A59228)
Lot of 4...
2016 Isuzu Box Truck (A60352)
2016 Isuzu Box...
2003 Sterling L9500 Series T/A Wet Kit Day Cab Truck Tractor (A59230)
2003 Sterling...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
