mini excavator stability?
   / mini excavator stability? #1
Ken45101
Elite Member
southern Ohio
Kubota M5040, M9540, B21 TLB, B2710, RTV900, JD 325 Skid steer, KX-121-3 mini excavator
I've been thinking about getting a mini excavator for use around the farm. I do not have any experience with excavators although I have a Kubota B21 TLB that I've put several hundred hours onto.
One of my planned uses is for building trails through our wooded hillsides and doing trail maintenance. Another use would be clearing the mudslides we have along our driveway. One of my concerns is stability. Are the units top heavy? I'm often nervous with the B21, worrying about it tipping over.
Right now I'm thinking about either a Deere 35D or a Kubota KX91. Any comments would be appreciated.
Thanks,
Ken
   / mini excavator stability? #2
If you don't use your head you can tip any machine over. Excavators generally will let you know well before it tips that what your doing isn't smart. If you try to lift too much with the dipper the excavator will tip till the dipper sets back down. I have ran 1 ton minis and 5 ton minis and have never worried about tipping one of them and never have felt close to tipping. Excavators are great machines for working hillsides because of their stability and traction.
   / mini excavator stability? #3
MiniXs are great for stablility, especially with the blade down and over the front lifting. Over the side you will feel when you might have a problem for sure, but believe me, you will let go of what you are handling before you go over. You will be more than impressed I think with the KX91, but I feel you should get the KX121 as it is much more machine and only slightly more $. I have 1 and I love the thing. You will be amazed how you ever lived without one. Get a grading bucket for high capacity moving jobs such as mud, stone, topsoil and other high volume jobs. Good luck.
   / mini excavator stability? #4
I would suggest you get one with steel tracks for steep and rough country as you will find the rubber tracks will come off frequently . Loose dirt will spill into the sprocket rail in the rubber tracks and cause the sprockets to climb out . Rubber pads on steel tracks are the best , they will stay on and give good traction , even walking over green saplings on a hillside will not cause them to slip .
   / mini excavator stability? #5
My kx 91-2 has been an excellent machine, if I had a choice now I would go with one size bigger, kx 121 but all in all my 91 does everything I need it to do. What amazes me is that I can run it on about a gallon an hour and it is so quiet. I almost lost a track once in rocks but I saw it in time and simply reversed and tightened the tracks a little and havent had a problem since.. hope this helps
   / mini excavator stability? #6
   / mini excavator stability? #7
That is a skid steer, not a mini excavators. They are completely different machines and act completely different. It is fairly easy to tip a skid steer.
   / mini excavator stability? #8
I have never even come close to tipping over, but I am not ashamed to say I have bounced my forehead off the glass at least 2X grapping something like a stump and breaking free only to violently smash around in the cab. All minXs have blades and with that down the stability is great, albeit 75% +/- reduced over the side. Some may say more. My KX121-3 is like a robot with a great operator like myself ( can you here the self-backslapping??!!) and sure is unbeatable in terms of flexibility, productiveness, and capability. Iwant a mower head so bad, but cannot justify the $. I have 3 bush hogs already. Grading bucket is the 2nd best thing for a miniX after the thumb. Never had steel tracks, but rubber is certainly best for anything other than severe duty applications. The longer the track is better, wait till you feel your back. Oh, and 0 turn excavtors have reduced capability to compensate for the counter weight being moved inward towards the center of gravity. Must miniXs that are not 0 turn are very close to it (like Kubota) and have much more lifting and breakout power than the 0's.
   / mini excavator stability? #10
why does a (presumably) self appointed super star with over 11k posts confuse a skidsteer for a minix??
eh, life's little mysteries.
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A52748)
2015 RAM 5500...
2024 Victor X-PRO Mini Dirt Bike (A50324)
2024 Victor X-PRO...
378807 (A51572)
378807 (A51572)
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
Tires (A50322)
Tires (A50322)
