Mini cat excavator Track adjuster leaking
   / Mini cat excavator Track adjuster leaking #1
edloney
I have a 1999 Caterpillar 301.5 mini excavator with 1100 hours and one of the Track adjusters [left side] seem to be leaking. I thought before I tore into it I would ask around to see if I could get some knowledgeable input. I have filled it with grease about six times and it works well for about two hours and then it needs to be refilled. The other side has never needed grease since I have owned the excavator [about 150 hours] - can this adjuster be rebuilt?
Many thanks Ed
   / Mini cat excavator Track adjuster leaking #2
Not sure what Cat uses for a track adjuster system, but my Takeuchi is fairly simple. Let the grease out, slide the entire assembly out, pull the O ring and plastic keeper out, replace both, slide it back together and reassemble.
My 025 was super simple, the 135 is a little slower, but simple just the same. Can't imagine Cat does anything too funky.
Thanks!! atgreene I'll get to it as soon as it stops snowing here in Bigfork Montana.
JOHN DEERE BACKHOE FORK ATTACHMENT (A53843)
JOHN DEERE BACKHOE...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
Light Tower (A52377)
HYDRAULIC FLOOR JACK (A53843)
HYDRAULIC FLOOR...
