Milwaukee M12 Tool Line
   / Milwaukee M12 Tool Line #51
I had an Milwaukee M18 angle grinder. I found it to be an absolutely miserable tool. It would go for a few seconds then turn off. I ended upgrading batteries which helped some, but ultimately didn't solve the problem. I got very quick at restarting it, but ultimately overheated and smoked the tool.
Since then I have jumped to Harbor Freight Hercules tools. And I've been mighty impressed with most of them. The Angle grinder in particular seems to have plenty of power and the only times I've stopped the grinder is when I twisted and bound the disc.
My corded DeWalt 1/2" impact is mysteriously underpowered, and I've moved to either Hercules or Earthquake cordless impacts.
   / Milwaukee M12 Tool Line #52
I have mostly M18 tools but have ended up with a few M12 tools for those lighter jobs. The M12 are great for tight spaces. The stubby impact will even break free the lug nuts on our pickup.
I have used Bosch, Panasonic, Hitachi, Hilti, Dewalt, and Mikita battery drills and impacts. They all have had pluses and minuses and it comes down to what feels right to the operator.
   / Milwaukee M12 Tool Line #53
Wish I had gone with Milwaukee. All my battery operated tools are Kobalt from Lowe's,
I found out they will discontinue Kobalt and go with Craftsman as their store brand..
The stubby impact is high on my list of next tools but the price even took only is up there.
Not sure I’m sold on the wrenches yet. I’m sure if I used one I would want one right away but can’t seem to justify yet.
The shop vac and ports air compressor are other options I’m interested in.
   / Milwaukee M12 Tool Line #55
I have a mix of Milwaukee and DeWalt cordless tools. I particularly like the Milwaukee M12 line for their compact size.
I also use the M12 batteries with this adapter to power other 12V devices, like this hand held fuel transfer pump:
   / Milwaukee M12 Tool Line #56
I was in the trades in the 70's and 80's. That is exactly how you pick the 'right' tools. My kids will inherit the 110v Rockwell, Milwaukee, Stanley drills, sanders, saws, routers i got from my dad. They won't die!
I've worn out a few cordless driil/drivers over the last 40 years. Had Festool for the last 10 years. It's used alot. Its the only cordless drill that has an 'inline' design. Can't stand T-handle drills!
View attachment 4327171 View attachment 4327172
That’s a pretty genius idea
   / Milwaukee M12 Tool Line #58
My larger battery tools are the older Dewalt 18v xrp. I wanted some smaller, lighter tools and got into the M12 series. I have been very satisfied with them. Probably the most used is the tire inflator and the 1/4 impact driver. I also use the M12 vacuum a lot. Very handy tool.
   / Milwaukee M12 Tool Line #59
I have a pretty wide selection of both M12 and M18 tools. The only ones I'm unhappy with are the M12 hacksaw (mini sawzall) and the M18 string trimmer. The hacksaw will only cut for a few seconds before it quits like it overheated or something. Even with light pressure. The string trimmer has a really annoying trigger that has to be fully depressed. If I'm not holding down the trigger with significant pressure it will stop. Also, the string head doesn't feed well and jams frequently. I'm happy with all my other M12 and M18 tools. The power of the M12 stubby impact surprises me - it has no trouble with lugnuts. I use the M18 impact when I need to be more persuasive but the M12 usually gets the job done and it's nice and light.
Try the newer Milwaukee autofeed head. I have puts hundreds of feet of line through it and it jams much less than the regular heads I had on my Stihl etc.
I have the M18 power head, pole saw and trimmer and have put hundreds of hours on them over the last 5 years, doing 1200 feet of driveway and probably another 1200 feet of trench and beds, Stiltgrass is a pain.
I also have the M18 air pump and use that a lot of topping off tires on tractor, cars. It works well and fast even on truck tires.
   / Milwaukee M12 Tool Line #60
I am considering upgrading to an expensive better-made pole saw. The M18 Milwaukee is one I am considering. That, and the Makita LXT 18V, a Husky, and an Echo. No M12 pole saws made, which makes sense. Stihl, just too expensive.
I am on my 2nd 40V Greenworks pole saw, after blowing up the first one. 40V power is just too much for it. I also used an 18V B&D NiCad for years before that.
Is yours the single-battery pole saw, or the dual (36V)?
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
Miller Millermatic 25 Welder, SKU# 907321, S/N MJ260223N, Rated Output-Amperage 200 (A59076)
Miller Millermatic...
Brent 420 Grain Cart (A56435)
Brent 420 Grain...
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
