Grapple Millonzi Grapple
   / Millonzi Grapple #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I have been interested in the Millonzi grapples since I first read about them several months ago. Since I would be using it with TC 40D NH machine with 17LA loader, I thought that the light root grapple at 48" would be my best bet for large rock picking, brush clearing and log moving since it is only about 250# and would not eat up large portion of loader's capacity. I spoke with their sales girl today, and she expressed reservations about whether the light unit would handle those jobs. The next unit up from it weighs over 700# and doubles the price. Any thoughts from someone that might own one of the lightweight grapples would be appreciated.
   / Millonzi Grapple #2
The person I talked to actually talked me out of the bigger unit. IMHO, a wider grapple limits its usefulness for digging things out. Go with the 48". I love mine.
-Brian
   / Millonzi Grapple #3
Send a PM to IslandTractor. He'll tell you all about it. You'd be surprised at what you can do with a lightweight 48" grapple.
   / Millonzi Grapple
Have never sent a PM. Have received them and replied, but never initiated. How do you do it??
   / Millonzi Grapple #5
Your initial plan was correct. The 48" "light" duty root grapple is very versatile and I don't think you can hurt it with a CUT loader. I completely agree that a larger grapple offers very little except to decrease your payload weight capacity. I've posted a bunch of photos over the past 9 months but here are a few relevant to your stated uses:
   / Millonzi Grapple #6
Glowplug did it for you!:D
To PM just put your mouse over the intended recipient's user name and click on the send "private messages" link. Then just create a new message with the intended receiver's username as the addressee.
   / Millonzi Grapple
10-4 good buddies. Looks like the ticket for me. Thanks. By the way, how many front remotes do you need to run it??
   / Millonzi Grapple #8
One. I actually run mine from a set of rear remotes. Works just fine and is a lot less expensive if you have rear remotes anyway. The advantage of adding a diverter valve to run it from the FEL hydraulics is not in my opinion the ease of control (just as easy to control with the rear remote lever) but rather that you can then have both the backhoe and grapple active simultaneously. I need to switch the lines back and forth as both implements share the same rear remote. I just dig first then switch and come back to do all the collecting with the grapple but having dual remotes would certainly be desirable if you are intending to run a BH and the grapple.
   / Millonzi Grapple #9
Hey Island, Why don't you run it from the FEL power beyond circuit? Just curious as I was planning to run mine that way. I see what your post says but if there was a elec switch on the loader joystick wouldn't that be easyer. My rear lever is on the same side a my FEL stick so it looks like it will really wear my right arm out.
   / Millonzi Grapple
Don't have a BH, but planning hydraulic top link. Guess I could use that feed for the grapple. I plan to have box blade in back for counterbalance. Can I disconnect the HTL line without losing control of BB??
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
Wells Cargo Enclosed Trailer (A50324)
Wells Cargo...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
1999 FREIGHTLINER FL80 (A50854)
1999 FREIGHTLINER...
2017 GEHL RS5-19 TELEHANDLER (A51242)
2017 GEHL RS5-19...
