Milling Hydraulic Cylinder Crosstube 0.040"
   / Milling Hydraulic Cylinder Crosstube 0.040" #1
Oldtoad
Kennebec County, Maine
Kubota L4310, Bolens-Isiki
While looking for a machine shop to mill down the end of a cylinder need to consider doing it myself on a small drill miller.
Machine came with a small fly cutter.
Where to start?
   / Milling Hydraulic Cylinder Crosstube 0.040" #2
Practice on something that isn't your only cylinder would be my first suggestion. If you don't know the machine and you don't know all the variables, such as cutter angle, depth of cut capability, known speeds and feed, then winging it can mess up your cylinder in a hurry.
Now if your an experienced machinist...
David from jax
   / Milling Hydraulic Cylinder Crosstube 0.040" #3
Where to start?
There are a few experienced machinists on TBN & can probably help. Some more specifics would help. Maybe a sketch. "mill down the end of a cylinder" is to vague. What are you trying to do?
Thanks,
Was a little frantic for a bit. The little miller is in a container, need the broke tractor to move the generator, ahh, went out for breakfast...
Was heading to a tractor store, saw a machine shop sign, pulled in.
Guy says show me.
He charged 1/2 hour to grind down the wide crosstube, he sent me to Traction Heavy duty parts for the new hydraulic cylinder adapter fittings and Kubota for a new gasket set.
The bent Kubota cylinder should be a week or so.
At least I can get back to work.
New Kubota cylinder would have been $940. Too expensive I thought, still on backorder.
New Magister cylinder $207, grinding $35, fittings $12.
Do not know how much the bent rod repair will be.
   / Milling Hydraulic Cylinder Crosstube 0.040" #5
Glad that is working out!
David from jax
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2020 INTERNATIONAL LT625 DAY CAB (A52576)
2020 INTERNATIONAL...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
