MILLER SPECTRUM 625 X-TREME Air Requirements
   / MILLER SPECTRUM 625 X-TREME Air Requirements #1
gnaws628
NE Oklahoma
I am considering the purchase of a MILLER SPECTRUM 625 X-TREME Plasma Cutter and need some advice on the air requirements. The specs. call for 6 SCFM (170 L/min) at 90 PSI MIN (621 kPa) 120 PSI MAX (828 kPa). My compressor indicates a capacity of 5.2 SCFM @ 90 PSI and it has a 30 gallon tank. Will it be sufficient to run the 625 and if not what kind of problems will I see with the smaller compressor? Thanks
   / MILLER SPECTRUM 625 X-TREME Air Requirements #2
I have a 5-HP, 175-PSI, 80-gallon compressor, so I never run out of air with my plasma cutter. I would think that if you don't have enough air, your plasma cutter will get a error and shut down. If this is true that will be a huge pain in the azz!:thumbdown:
Are you going with an air dryer?
   / MILLER SPECTRUM 625 X-TREME Air Requirements #3
Length of (spec) burn/cutting time will be the issue! You could adapt/overcome by cutting then waiting for the compressor to refill.
Yes I am planning on using the recommended air filter for the unit. Assume that is considered an air dryer.
   / MILLER SPECTRUM 625 X-TREME Air Requirements #6
Why not buy a cutter that is within specs of your compressor?
It looks close enough to work but you may have to wait a lot.
RC
RC
I am wanting to cut at least 1/2 inch with ease so need the larger machine. I purchased a Hypertherm 45 so will see how it works with my compressor. Thanks for the input.
   / MILLER SPECTRUM 625 X-TREME Air Requirements #8
Maybe a YouTube video to follow? Or at least pictures?
Thanks and congrats on the purchase of a great machine
   / MILLER SPECTRUM 625 X-TREME Air Requirements #9
The 325 xtreme will cut 1/2 fairly easily. In fact, I have done it on 120V. 240, works fine. It' isn't zip fast, but on 1/2", you'll need an 60 or 80 amp to do that fast.
2018 Triple Crown 8ft Utility Trailer (A42742)
2018 Triple Crown...
2020 Chevrolet Equinox LS SUV (A42744)
2020 Chevrolet...
Veris 3-Point Soil Management System (A44789)
Veris 3-Point Soil...
LARGE LOT OF ASSORTED SHOP ITEMS (A40517)
LARGE LOT OF...
7021 (A39855)
7021 (A39855)
NEW MAKITA 2 SPEED HAMMER DRILL- HP2050- 1 YR FACTORY WARRANTY -RECON NEW SUPPORT EQUIPMENT (A40019)
NEW MAKITA 2 SPEED...
