MILLER SPECTRUM 625 X-TREME Air Requirements
   / MILLER SPECTRUM 625 X-TREME Air Requirements #1
gnaws628
NE Oklahoma
I am considering the purchase of a MILLER SPECTRUM 625 X-TREME Plasma Cutter and need some advice on the air requirements. The specs. call for 6 SCFM (170 L/min) at 90 PSI MIN (621 kPa) 120 PSI MAX (828 kPa). My compressor indicates a capacity of 5.2 SCFM @ 90 PSI and it has a 30 gallon tank. Will it be sufficient to run the 625 and if not what kind of problems will I see with the smaller compressor? Thanks
   / MILLER SPECTRUM 625 X-TREME Air Requirements #2
I have a 5-HP, 175-PSI, 80-gallon compressor, so I never run out of air with my plasma cutter. I would think that if you don't have enough air, your plasma cutter will get a error and shut down. If this is true that will be a huge pain in the azz!:thumbdown:
Are you going with an air dryer?
   / MILLER SPECTRUM 625 X-TREME Air Requirements #3
Length of (spec) burn/cutting time will be the issue! You could adapt/overcome by cutting then waiting for the compressor to refill.
Yes I am planning on using the recommended air filter for the unit. Assume that is considered an air dryer.
   / MILLER SPECTRUM 625 X-TREME Air Requirements #6
Why not buy a cutter that is within specs of your compressor?
It looks close enough to work but you may have to wait a lot.
RC
RC
I am wanting to cut at least 1/2 inch with ease so need the larger machine. I purchased a Hypertherm 45 so will see how it works with my compressor. Thanks for the input.
   / MILLER SPECTRUM 625 X-TREME Air Requirements #8
Maybe a YouTube video to follow? Or at least pictures?
Thanks and congrats on the purchase of a great machine
   / MILLER SPECTRUM 625 X-TREME Air Requirements #9
The 325 xtreme will cut 1/2 fairly easily. In fact, I have done it on 120V. 240, works fine. It' isn't zip fast, but on 1/2", you'll need an 60 or 80 amp to do that fast.
Margaritaville Wall Art (A55853)
Margaritaville...
Deere 320 (A53317)
Deere 320 (A53317)
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
John Deere 1025R (A53317)
John Deere 1025R...
UNUSED FUTURE CLG72 72" HYD CURVED LOG GRABBER (A57193)
UNUSED FUTURE...
