Miller Bobcat engine issues
/ Miller Bobcat engine issues #1
joeu235
Platinum Member
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
I've got a 225 Bobcat welder, Onan 2 cylinder engine, that has started surging at full throttle, won't stay running at idle, and occasionally backfires when restarting. Anyone have an idea what's going on?
/ Miller Bobcat engine issues #2
If yours is equipped with a vacuum operated fuel pump, like mine was with somewhat similar issues, changing to a small volume electric pump might solve the issue.
/ Miller Bobcat engine issues #3
If old enough it drank MTBE gas pretty good chance perforated diaphram in fuel pump. Replace before gas takes out crank bearings or wish you did.
Best to just replace fuel pump wid low pressure electric.
/ Miller Bobcat engine issues #4
I agree, sounds like running lean so either carburetor or fuel pump if equipped
/ Miller Bobcat engine issues #5
I have a Lincoln Ranger 8 that had the same issue. I switched it to Propane. No more issues with gas.
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
John Deere 185 Hydro Riding Mower (A66285)
John Deere 185...
2017 International HX620 Quint Dump (A62613)
2017 International...
2022 EZ-GO ELITE...
2009 Bobcat T190 (A64126)
2009 Bobcat T190...
2018 Case 650M OROPS Dozer (A62679)
2018 Case 650M...
