milky Hydro fluid
   / milky Hydro fluid #1
tawn
Seaford Delaware
John Deere/310C Turbo 4X4
I just bought a used JD310C Backhoe and someone replaced the filter inside the hydro tank. He did not seal the hole that he cut in the top of tank therefore water got into the system. Since then I have drained tank, sealed hole good, removed all lines and pumped out what I could of the cylinders. I know that I might have to change fluid maybe a couple times to get all the milky out, but my question is when I fill hydro tank , do I have to prime hydro pump or will it pull fluid to pump? another thing is will I have to fill cylinders or crack lines at cylinders to let air escape? or will pump fill cylinders ?
   / milky Hydro fluid #2
If the tank is full, the tractor should prime itself.
As far as air in the hyd system, just cycle all cyl many times to purge the air. If you continue to have air in the system, check the suction hose for leaks.
   / milky Hydro fluid
Thank you for your info, as a first time owner I am sure I'll be here again.
   / milky Hydro fluid #4
J_J is spot on just cycle all cyl
   / milky Hydro fluid #5
Sometimes milky fluid can be caused by air in the oil as well as water...
   / milky Hydro fluid #6
Emulsified fluid is very different from air entrained fluid.
   / milky Hydro fluid #7
A question for you J_J . If you work the tractors hydraulics hard enough so the oil gets above 212F will the water boil off and clean the system?
   / milky Hydro fluid #8
Don't think so, besides, that kind of temp is not good for hyd fluid.
When there is water in the hyd fluid, other chemicals are being made.
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
2014 KENWORTH T800 MIXER TRUCK (A53843)
2014 KENWORTH T800...
SKID STEER BRUSH ATTACHMENT (A53843)
SKID STEER BRUSH...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
DITCH WITCH FX30 VACUUM TRAILER (A51406)
DITCH WITCH FX30...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
