Milky Hydraulic Fluid
   / Milky Hydraulic Fluid #1
mauzi
Hi there,
first of all thanks to everyone, with your suggestions my MF 245 is back in field :) did clear all the snow yesterday finally :). but just a concern, before hydraulic fluid in loader tank was contaminated, was milky and frozen. this tractor has different fluid tank built right in one of the loader arm as previous guy said he needed 3200psi and front mounted pump, which I think is good to have totally different fluid system and pump for loader . anyhow i warmed it up and took pretty much everything out, put some new fluid, ran system and drain that one too! finally filled the tank with fresh fluid, it took close to 15 litters, but still milky. Hydraulics seems working just fine but not sure what to do. It will be parked outside so really don't wanna go through the whole process again.
Good thing - oil in Transmission Differential reservoir is nice and in good shape :)
please advise.
thanks
MG
   / Milky Hydraulic Fluid #2
Just by draining the tank isn't enough as you need to drain all the lines, filter,and cylinders as well.You still have oil in the cylinder and hoses so its more then just doing the tank.I know its a pain to do but needs to be done.Hope that helps and good luck.Larry:D
I did open 2 cylinders out of 3 but still have some. I guess, I am going to park in inside the shop this winter, and hopefully get it all out in 2-3 flushes.
   / Milky Hydraulic Fluid #4
I don't know how cold it gets where you are but I had a MF 150 with same setup oil in right loader support,when it was real cold out it would make a lot of noise and the hyd were slow till it warmed up I replaced the hyd oil with ATF and never had a problem.
Several years later I was talking to a MF dealer and they told me they did the same thing.
thanks ALL, went to MF dealer in our area, he suggested to park it inside this winter as shop is heated. But in summer add a quarter tank of diesel run the system and drain. Then I will add ATF as kenstrac suggested. Didn't talk to dealer about adding ATF but I believe it will be far better than water+hydraulic fluid. :)
thanks all again.
Mauzi
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2012 CHEVROLET 3500HD SILVERADO LS DUALLY TRUCK (A51247)
2012 CHEVROLET...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52576)
2019 INTERNATIONAL...
NEW Mini Excavator Fixed Thumb Attachment (A53002)
NEW Mini Excavator...
