Mildew in boots
   / Mildew in boots #1
DrRod
Platinum Member
Ellicott City, MD - Farm in Orbisonia PA (south ce
John Deere 4110
It has been so wet here for the past few months that everything in the cabin and outbuildings is damp. When I arrived I wet to the closet for my boots and they were covered in blue mildew -- inside and out. I can easily wipe the smooth outside surfaces but the inside is more of a rough out surface. Should I submerse them in order to clean them out or is there something like Lysol that I should spray I there.
   / Mildew in boots #2
put them on and wear them. Then put a desiccant in the closet
alot of the time mine are covered in cow shyt and I don' t worry about it , bleach will clean the socks when they are laundered
   / Mildew in boots #3
Buy a de-humidifier on Amazon for your closet. The brand I have is Frigidaire.
   / Mildew in boots #4
They tell me rice works but i haven't tried it.
   / Mildew in boots #5
Where's our Houston and New Orleans members when you need them? :laughing:
   / Mildew in boots #7
Them boot warmer/driers work great.
   / Mildew in boots #8
I'm glad I don't have that problem. For me it's leaving them wear a critter might make a mess. After a couple times sticking my foot into a boot and getting a scare/surprise... I always bring them in and put them near the fire or heat source. Never out in the garage now. I have also bagged and ziptied them if I know I'm not going to use them for a long period and store them in an unheated area (ski boots) but of course they need to be dry first!
   / Mildew in boots #9
I would mix up a mild bleach water solution, and rinse them out with that before a good clean water flush. Then dry them out with a boot drier. Keep the closet doors open at the cabin to allow a little more air flow and that will probably be enough to keep them mildew free. If it's a small closet you could use a gun safe style goldenrod dehumidifier in there and keep the door closed. Or even a small incandescent light bulb will keep it dry.
Quick Attach Accumulator Grapple (A50514)
Quick Attach...
Kubota SVL95-2 High Flow Cab Skid Steer (A52128)
Kubota SVL95-2...
2018 Nissan Versa Sedan (A50324)
2018 Nissan Versa...
John Deere D110 42in Riding Mower (A49461)
John Deere D110...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
2013 RAM 5500 (INOPERABLE) (A50854)
2013 RAM 5500...
