Mike
Mcroce
Ny
Kioti cs2410
Just looking for some advice on how to replace a shear pin on a Kioti snow blower - the auger
/ Mike #4
Just measure the pin dimensions and find the closest fit at TSC or hardware store. In my experience Kioti uses some nonstandard pins and bolts, so a perfect fit really doesn't exist.
/ Mike #5
How old is your blower. Mine is 2013 sb66. The shear pin area is located under a flat cover which is just over the chain sprocket on the left side of the blower. Like in the pic below it has the 2 black/yellow grease gun stickers on it. Take snap pin out and lift cover. You will see two flat pieces with a hole in it. I found turning the driveshaft by hand is the easiest for lining up the holed for the pin. Make sure tractor is not running when doing this. Hope this helps
To make the pic bigger click on it and then you can zoom in to see better.
Hi Mike
Are you the Mike Croce who works at Queensbury NY, Sterigenics plant?
If so, it's nice to run into you here.
John Gilbert
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
Rosco RB-48 Broom (A65579)
Rosco RB-48 Broom...
14ft. Disc (A65640)
14ft. Disc (A65640)
2017 Mack Semi (A64047)
2017 Mack Semi...
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
84in. Skid Steer Bucket (A65640)
84in. Skid Steer...
