mihindra 3510
   / mihindra 3510 #1
blueovelwookie
andalusia alabama
mahindra 3510
i am getting oil and diesel, combined in the oil, i have been told that it is the the fuel transfer pump, i need help please, tractor is working great but since last oil change i am getting fuel mixed in with oil. about a quart+ a month, and i am concerned... any help is appreacieated,,,(spelling is not my forte so please forgive me at my spelling errors)
thanks
Brett
   / mihindra 3510 #2
If you are sure that fuel is mixing with the oil, pls take it to the dealer...NOW. Pls don't be one of these guys that keeps on running the maching till something drastic happens and then blame the machine...it may be something simple, so if you want to keep a good tractor, call the dealer now...BobG in VA
   / mihindra 3510
i am out of warrenty, and as soon as i noticed the mixture, the tractor was taken to my fatherinlaws diesel machine shop, and we are in the process of diag, the only good thing is most of our cust are fimiliare with tractors. but this issue is stumping all of us. :confused:
   / mihindra 3510 #4
Something came to me while I was reading your last post...just a thought...you may have a cracked compression or oil ring on one of your pistons....It wouldn't interfer a lot with running capability but raw diesel could get by to your crankcase if you aren't getting full ignition due to lowered compression ratio....BobG in VA
   / mihindra 3510 #5
We had a cat motor in a semi do that and it was a bad injector. I am no mechanic but it sounds the same as our problem.
   / mihindra 3510 #6
We have Detroit Diesels at work that do that from time to time, and just like the Cat motor in the previous post, it was attributed to the injectors. The crank case would get fuel in it, and it would dilute the oil to the point where the oil pressure dropped and shut the engine down.
That's worth looking into
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
CONTACT INFO (A53084)
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
2001  WABASH 53FT DRY VAN TRAILER (A54607)
2001 WABASH 53FT...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
