Might Need To Hot-wire My Kubota
/ Might Need To Hot-wire My Kubota #1
BlackSmokeLust
Northern Colorado
Kubota BX2200
Hello,
This is my first Kubota and after 2 weeks of sitting it will not start.
At first when I turned the key to 'ON' I could see the battery light and hear the fuel pump, then on 'PREHEAT' could see the glow plug light but no start, not even a click or pop. After a few turns of the key the lights would get dimmer and dimmer.
Next day battery was replaced.
With new battery installed I had hoped to have it running. Turned key to 'ON' battery light was bright, seen glow plug light for first time in awhile, tried to turn it over and nothing. Now the glow plug light won't come on and battery light is dim for first few turns then won't come on at all. IC Regulator?
Last week I installed a new switch but still nothing. I noticed I am getting .98 volts to the starter BW wire and nothing to the W wire (safety switches bypassed for troubleshooting). I am hoping it's the Stop Solenoid but because the battery light disappears after a few turns I am thinking it's something else as my power to the glow plugs is also less then 1 volt as well. I am getting 12+ volts to my slow blow fuse. All others that I could find I replaced just in case. This model does not have the Timer Relay.
I need to get this into my garage and now that I have an extra ignition switch thinking of creating an isolated start/run circuit just to get it to move. Has anyone done this?
_________________________________
2003 Kubota BX2200 w loader 1k hours.
/ Might Need To Hot-wire My Kubota #2
Just to clarify what you're saying... when you put in new battery, the starter did crank the engine briefly, but the engine never did start, and the battery drained down very quickly, right? How much cranking was it? 30 seconds? 2 minutes? 10 minutes? ??? If a fully charged battery is drained in less than, say, 2 minutes, the cables would be really hot, as well as the starter. Did that happen? Any possibility the new battery wasn't fully charged? Have you tried jump starting it? Was it running OK 2 weeks ago? How long have you had it? It has fuel, right? Are fuel filters (both) OK?
Maybe someone who knows more than me will have some more ideas, but I'm trying to figure out if you have a short that is drawing down the battery, whether it wasn't fully charged, you have a bad connection that is blocking current, you have a dead short somewhere, some component is not working right, or maybe it's something non-electrical.
When I put the new battery in it made no difference other than my glow plug light came on for a few turns from the key 'PREHEAT', no starter crank at all. I have full 12+ to the starter and can get the starter to turn if I jump it. Today when I was troubleshooting the best I could get was a dim battery light from the dash even with a charged battery.
Reset your meter to include tenths please. 12 point what ?
Was this reading taken from a good ground like starter mount bolt and main heavy starter lead in ?, if not , where ?
Before I packed up for the night it was at 12.89. I did have the ground attached to the negative terminal of the battery.
I don't remember what the exact reading at the slow blow fuse was but it was close to the 12.89.
/ Might Need To Hot-wire My Kubota #8
12.8 good, I'll assume that was during 'non' crank.
Best to start at 'starter + heavy term' and work back from there if voltage loss during crank.
/ Might Need To Hot-wire My Kubota #9
The reason I'm leaning towards a high amp voltage loss was your .98 voltage reading.
Even a bad battery reads better than that.
/ Might Need To Hot-wire My Kubota #10
Take your ground wire off at both ends and clean. See if that helps.
When I use a jumper wire from the positive battery terminal to the white wire on the starter it spins but the solenoid does not push the gear out. I am hesitant to add 12 volts the BW solenoid wire since the WSM states to use 6V to test it.
/ Might Need To Hot-wire My Kubota #12
2 wire starter ?, 1 heavy batt cable size, 1 light (12ga) ?
I don't know what "white wire on the starter" "BW solenoid wire" + "WSM" means.
/ Might Need To Hot-wire My Kubota #13
Do you have a small red or white wire and a larger red wire to the starter? if so then your starter is grounded via the metal casing of starter and engine. The little wire is the start and big red wire is power to spin the motor of starter. Jumper those two posts on starter and see if the solenoid kicks out the engage gear. If it wont, its possible you may have a bad starter. Try taking the starter off motor and clean the post contacts and the body where starter touches the engine and remount. If it still won't work, then most likely you need a new starter. good luck.
Sorry. WSM as in Work Shop Manual. BW as in black and white.
Here is the schematic I have been referencing.
[/IMG]
Yes, the starter is grounded via the casing. When I apply 12 volts to the white wire the starter turns but solenoid does not pop out. Looking at the schematic it appears the safety switch circuit needs voltage to engage the starter solenoid as well. The manual states to use 6V to test the solenoid and that is keeping from running a 12 volt jumper to it.
/ Might Need To Hot-wire My Kubota #16
okay- if starter turns, but solenoid not working, you already confirmed the issue. your solenoid is bad or sticking. find out if you can get a replacement solenoid, if not, I'd try the local autostores for a compatible solenoid for it otherewise you would need to pony up cash for whole starter/solenoid.
I'll try and post the troubleshooting instructions for the starter solenoid. According to the manual you have to apply 6V of voltage @ 3-5 seconds to the solenoid to test, the black and white wire. According to the schematic the power to the solenoid comes from my safety switch circuit which currently has only .98 volts. This is completely different from the white wire that spins the starter.
According to the manual, in order to test the starter there are two procedures, one to test the motor spin and the other to test the solenoid.
I pulled the starter off yesterday and am ready to send it in for a rebuild if need be but would really like to bench test it myself though I don't want to go out and buy a 6V battery just for that.
Because the starter uses 6 volts on the solenoid I was hoping whatever is reducing the voltage might be the problem such as the IC Regulator.
/ Might Need To Hot-wire My Kubota #18
If you have a 6/12 volt battery charger, you can use the 6 volt setting to test
/ Might Need To Hot-wire My Kubota #19
Take a small hammer and tap the solenoid a few times and then try it again.
Note; tap does not equal bash.
/ Might Need To Hot-wire My Kubota #20
2005 CATERPILLAR 345CL EXCAVATOR (A60429)
2005 CATERPILLAR...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
14C SCRAPER (A58214)
2018 Ford F-150 Ext. Cab Pickup Truck (A59230)
2018 Ford F-150...
