Might have fried the alternator in my 1700...
   / Might have fried the alternator in my 1700... #11
Depending on how it's wired, if the alternator is putting out at all it could go wide open providing sixteen volts to the battery. You'd be better served just trying to run it without the battery. If you don't have any computer stuff the battery is only used to start and power the indicators and lights anyhow. You will need to put the battery on a charger from time to time running without the alternator.
an alternator with wye windings could put out 130 Volts!. not good at all for a battery or the rest of the tractor!.:eek: a high output alternator such as a leece neville uses delta connected windings which can put out 60 volts+. you'd burn out everything connected to it!. the leece neville and some others use avalanche diodes which break down and short out at 30 Volts, but even that can cause damage to electrical systems. What are avalanche diodes in an alternator? How do they function? - Quora
2013 Ford F350 (A55973)
2013 Ford F350...
2020 FREIGHTLINER CASCADIA SLEEPER (A57880)
2020 FREIGHTLINER...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56435)
2020 Westfield MKX...
