Might buy a Yanmar and need help
   / Might buy a Yanmar and need help #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I am thinking of buying a used or new Yanmar--none in particular--and have no idea what the model numbers mean or advantages or disadvantages of different ones. I am a Yanmar newbie and need a 25 to maybe 27 HP in 2WD to make into a cultivator tractor.
I am drawn to Yanmar because I have had John Deere things that are Yanmar and have been very impressed. I like their engines. I also like the look of the Yanmar and more models are available in 2WD.
As well, I figure others may not know of the particular quality and I might be able to pick up one used at an auction or new at a dealer at a good price.
The number system seems baffling and I hope someone can steer me into a way to know HP or size of tractor at a glance. Are there any models to avoid or any to search out?
I don't need a loader, just a 2WD gear tractor--hydro OK--that won't give me too many problems. Thanks in advance for any advice.
   / Might buy a Yanmar and need help #2
according to my records a ym2210 2wd 3 cyl is rated about 25 hp with power shift. a ym2310 3 cyl 2 wd is rated about 26-27 hp with power shift
Check with Wayne . He is in Ohio http://www.lmtcompany.com/prices.html
   / Might buy a Yanmar and need help #3
I second kenmac's recommendation to check with Wayne. He is in SW Ohio and has some of the best equipment in this area.
I also swiped this quote off of his website...........
All units we sell will have ROPS & all other required UTDA equipment, regardless of the picture. Price includes completion of UTDA certification if tractor is currently not certified. Please see www.UTDA.net for information
   / Might buy a Yanmar and need help #4
At least with Wayne, You know what u r getting. Buying at auction is like opening a box of chocolates. U never know what u may get:D
   / Might buy a Yanmar and need help #5
kenmac, my 2210BD is 2 cyl, I thought all the 2210's were 2 cyl, am I wrong? At any rate sixdogs go with a UTDA dealer, you will be better off in the long run. Buying my Yanmar was the best thing I have ever done for myself. It is a good strong unit.
   / Might buy a Yanmar and need help #7
kenmac, my 2210BD is 2 cyl, I thought all the 2210's were 2 cyl, am I wrong? .
U r correct. I was in a hurry to leave & hit the wrong key:eek: It is a 2 cyl
Thanks--am getting some good advice here.
I like the 3 cyl 2WD so that is my direction at the moment. Is there anywhere that might list suggested retail prices of new tractors? I'm hoping to find a used private seller or auction but may buy new. Not sure if I should be concerned about a grey market tractor. Is there a way to figure out which models are NOT grey market tractors?
I've started looking around and found these two Yanmar items
http://www.hoyetractor.com/
http://www.yanmarowners.com/index.htm
They should advertise here so someone knows they are out there
   / Might buy a Yanmar and need help #10
Hoye is the sponser for the Yanmar Forum. Good folks to deal with. Only into parts though.
Bruce
FRUITLAND RCF 500 VACUUM PUMP UNIT (A53843)
FRUITLAND RCF 500...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53473)
2021 NEW HOLLAND...
