Mig worms..
/ Mig worms.. #1
Rusty4242
Western Mass.
Kubota BX23
I was using my Millermatic 175 to weld the seams of 18 gallon hydraulic oil tank
for the splitter I'm finishing. The seams were smooth and sound until I started seeing short "worm" like formations growing right after I stopped welding. They look like those worms of ash you see from those little burning pellets you can get a the fair. The argon / co2 is low but not empty. What's up, you welding experts?
/ Mig worms.. #2
Sounds like a shielding issue or contamination. I'm sure someone will know for sure...
/ Mig worms.. #3
I think that is your problem. I have had problems also tying to use the last little bit of gas in my tank. The guy at the welding/gas supplier said when the tank gets low, it's mostly just CO2 left...
/ Mig worms.. #4
I think we need pictures.
Are the "worms" forming out of voids left in the welds or are the welds themselves taking on the appearance of the worms?.
/ Mig worms.. #5
I have found in my little amt. of experience is contamination is 99% cause of worms growing after the weld.
Every now an again I will get a gust of wind right at the end of a weld and get a grow worm.
I refill my bottle when I get down to @ 100psi.
/ Mig worms.. #6
Contamination, either low gas or oil on the metal. Try grinding metal clean if you already aren't.
/ Mig worms..
It turns out that the problem was the gas. There was still 250 or 300 PSI left
in the tank. Hooked up a full tank and was off to the races with no problems, once the new gas got thru the hose. Those bubbly worms were hollow and slag like. Ground them off and rewelded those spots. Thanks for the help, Larry
I'll post a photo of my splitter when its done.
/ Mig worms.. #9
That is exactly where my tank was when I started having problems...Glad it was nothing major:D
2016 Jeep Compass SUV (A66738)
2016 Jeep Compass...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
20 FOOT SHIPPING CONTAINER WITH CONTENTS (A68842)
20 FOOT SHIPPING...
WHOLE PARTS ROOM (A68842)
WHOLE PARTS ROOM...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
