Mig welding thin steel
   / Mig welding thin steel #1
mitchash
Greene, NY
Mahindra MAX 28XL, Jinma 254 (Sold)
I have a Hobart 210MVP that I really like! I’m rebuilding a vintage dirt bike muffler that is around 18 gauge steel. I have already cut it open and made the repairs. Now I’m in the process of welding everything back together. My problem is I keep burning through every once in awhile. I have made several adjustments with little luck. I was managing, doing short welds when I ran out of wire .023”. Anyone have any advice before I get back to it. I’m on voltage setting 2 and wire speed between 24-28. That seemed to work the best. What’s a good gas setting? I’m running around 20 cfh. The only thing I haven’t tried was plugging it into 120v outlet. Thanks
   / Mig welding thin steel #2
If you will be doing a lot of thin gauge work in the future, invest in TIG. Or just keep on keeping on with what ur doing but try some aluminum heat sinks near the weld ( of course success will be limited when trying to close up a cylinder shaped object like a muffler).
   / Mig welding thin steel #3
If you're holding the nozzle so it's pointing straight down into the weld, lean it to one side at least 45 degrees and try dragging short zaps. Having a wet rag handy to douse it with to keep the heat buildup in check helps too.
   / Mig welding thin steel #5
If you push the nozzle vs drag, it wont burn through as easy.
   / Mig welding thin steel #6
Short quick zaps instead of trying to run one long bead.
I do have a tig welder, it’s a multiprocess welder, plasma cutter. I tried using the tig on it awhile ago and didn’t have much luck. I need to take a welding course on it or something. I haven’t used a tig welder since the late 80s early 90s.
This is the first muffler I did, the one I’m doing now is the same thing.
You can always gas weld it.
I just have a really small torch set. It has the disposable bottles, oxygen and gas.
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
2005 Mack CV713 Granite Truck, VIN # 1M2AG11C55M020965 (A51572)
2005 Mack CV713...
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53472)
Kubota SVL65-2...
