MIG Welding. Can't see what I am doing. Is it Just me?
   / MIG Welding. Can't see what I am doing. Is it Just me? #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
I always had trouble seeing far away. I wear contact lenses. At 53, the last ten years has been tough, being an electronics technician. I enjoyed excellent close vision for many years. Now, it's all a struggle, and I need so much light, it's not even funny. Working in dimly lit places and all the color information is gone!
I would probably be a better welder, but I just can't see what I am doing. If I can feel the work, as in welding in a V, I am fine, but otherwise, I go off track. Like, if two peices were butted together, I would not be able to see that junction point at all! Very, very frustrating for a perfectionist!
I have given my auto helmet to welding friends (who have perfect eyesight) and none has had issue with it, because I thought that might be the problem.
Do they make corrective lenses for helmets, like reading glasses? I'm not even sure this is the problem.
Any ideas?
   / MIG Welding. Can't see what I am doing. Is it Just me? #3
I have to wear my reading glasses inside the helmet, or I'm in the same boat......can't see worth s...
   / MIG Welding. Can't see what I am doing. Is it Just me? #4
Just do what I do. Go to the dollar store and buy a cheap $1.00 pair of readers. When I raise my hood I can still see if I need to add some weld etc, to the project
   / MIG Welding. Can't see what I am doing. Is it Just me? #5
I had the same problem you have until I tried the magnifying lens that inserts on the inside of the lens. I also use an adjustable auto darkening hood.
   / MIG Welding. Can't see what I am doing. Is it Just me? #7
I'm 37 and have had to start using reading glasses the last couple of years since I can't focus up close any more. I wear them under my helmet. Almost as much of a concern as good eyesight is proper lighting. If you are welding with background light, it reflects inside your helmet and causes focusing issues. I find it helpful to illuminate my weld joint from the front so that I can maintain good visibility of the joint. Especially helpful if you aim your worklight to cause a shadow across the welded joint. The added light won't affect your lense, but you'll notice that you can maintain peripheral visibility of the butt joint and still watch your puddle.
Edit: I just found this: https://www.youtube.com/watch?v=8pWWl0anhX4
   / MIG Welding. Can't see what I am doing. Is it Just me? #8
Yep. I have to have additional light on the weld, or I can't see the weld with the mask on. Also a rag over the top of the helmet to block out the light from behind my head is very helpful.
Aaron Z
I have a helmet made by "Speed Shade". Something from Princess Auto, that my Mother bought me as a Christmas gift maybe fifteen years ago. It is not adjustable.
As far as light goes, yes I know light getting into the back of your helmet can be a problem. As far as light on the work, I always figured that with a few million candle power from the arc, what difference is a few hundred watts of extra light?
Wearing contact lenses, I still have that notion in my head about an apparently unfounded warning of the ultravilolet light drying up the moisure layer between eyeball and lense causing the lense to be permanently fused to the eyeball.
I do have what most people would call a floater. Most annoying at times. I have never heard of the relationship between floaters and welding mishaps, and I did look, but mine happened over a dozen years ago in a welding mishap. I was grinding, welding, grinding, switching between welding mask and grinding goggles and I got them mixed up! That was with a stick welder.
   / MIG Welding. Can't see what I am doing. Is it Just me? #10
I have something similar, a "MetalMan" helmet (MetalMan Solar Welding Helmet with Grind Mode, Model# ADF700SG | Welding Helmets| Northern Tool + Equipment).
The difference is that the arc is very focused and the floodlight fills in the rest. Otherwise, (for me at least) I get a bright spot, but nothing around that. Last night I was welding with a Miller 211 on the inside of the fender of our B7500 and putting a 18v light there to "fill in" and it made a huge difference both when I was welding and when I stopped and the lens went "clear"
Aaron Z
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2018 Ford Fusion Sedan (A53424)
2018 Ford Fusion...
2002 Wacker RD11A Tandem Smooth Drum Roller (A55851)
2002 Wacker RD11A...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
JCB 409T4 WHEEL LOADER (A52707)
JCB 409T4 WHEEL...
