mig welder preferences
   / mig welder preferences #1
Dale1995
Caribou,Maine
John Deere 2320
What are you guys using for a mig welder, what are your recommendations, specific brands to buy or stay away from? should I go for a 110 or 220 model. How much amperage do I really need? I hate to spend money on too much or too little welder. I will be using it for general repairs around the home and on my tractor. I would also like to fabricate items like trailers etc... Any good sources for buying this welder? Thanks for all your imput.:confused:
   / mig welder preferences #2
I would also like to fabricate items like trailers etc... QUOTE]
If you are going to be doing this type of work where failure could run into serious liability problems it may be advisable to take some courses. After the courses you should know what type of welder is suitable!:D
   / mig welder preferences #3
Lincoln, Miller, Hobart, 220v units are just some of the better brand names. It all depends on your funds. I would say not go lower than 175 amps for a MIG welder. They will take .023 up to .035 wire, maybe .045 MIG wire or flux coated wire. Other people are going to tell you different things, so take it all in and select the best you can, with what you have. MIG wire has to use an external shielding gas, like CO2 , Stargon, etc or several others. Flux coated wire makes it's own shielding gas.
   / mig welder preferences #4
Hobart Handlers are good homeowner units - the 110v models will do surprising amounts of work, but the 220V models will do it better.
Another good one to look for is a Miller 250. Lots of auto shops use these, so if you're looking to go into production, you might want to look more towards the commercial welders (even used).
The craftsman mig welders used to be made by Lincoln, but I'm not sure who's making them these days.
flux core wire will work, but it's messy and difficult to get a pretty weld with it.
CO2 or Argon blend shielding gas is the way to go.
A low cost way to find out what you want/like would be to rent a couple different models for a day and try them all out.
   / mig welder preferences #5
i just bought a Hobart Handler 210 and so far am very impressed. i did some looking & went with this brand because every place i went to had all the accessories. easy to find consumables for it. it has a 5/3/1 year warranty. lincoln was the next one, sears & lowes carried these but didnt have the supplies like hobart did. miller was no where to be found more for industry i think. tractor supply has the Handler 210 for 799.99 right now & tons of accessories. my 2 cents there are many welders out there flip a coin.
   / mig welder preferences #6
When selecting a Mig welder look for differant adjustments and the specs. I like one that has a lot of adjustment for wire speed and voltage. Many low cost welders don't have a lot of fine tuning and you must change technique to compensate. When welding different thicknesses you will want to be able to fine tune the voltage(heat) and wire speed. You should look at duty cylce too. Don't be fooled by a welder that has lots of amps but only 20% duty cycle at 3/4 the capacity of the welder. There's a lot of hury up and wait with those. I use a Millermatic 250 at work and really like it. I hate welding with shielded wire, 'cause it doesn't look as good as using a shielding gas, but it's better if welding outside and windy 'cause shielding gas just blows away. Same with inside the shop close to a fan-gotta shut off the fan to weld. That's where shielded wire comes in handy. 145 amps is good for up to 1/4 inch on a single pass, but remeber.. if your welder is maxed out at 145 that may lead to short duty cylces depending on the welder. 1/4 inch can be welded with less but will require a little more prep and more passes. Hobart is ok but I would lean towards a Miller for mig. I just bought a Snap on Muscle Mig for at home but haven't had a chance to use it yet. I went with that one over a Miller 'cause of the 100% duty cycle at 145 amps, and it'll Tig weld and will work with an aluminum spool gun.
   / mig welder preferences #7
If you are ONLY going to weld thin materials, then 120v is good to go. But, if you want to also do some welding of thicker materials, you will want 240 single phase.
The key specs are;
Duty cycle - higher is better, rated at maximum output
wires used - 023, 030, 035, 045, etc.
Maximum output
Adjustability
Accessories. - things like an aluminum wire puller, TIG, etc.
I used to have a harbor 110v 105 amp welder. It worked fine for thin stuff. It got marginal when you would do more than a wee little bit at once. Duty cycle was horrible and weld quality dropped slowly before it cut off with overheat. That was replaced with a Lincoln SP255 with 250 amps output and 50% or so duty cycle. Much more of an industrial unit, but it has never let me down.
jb
   / mig welder preferences #8
I personally have 3 welders. 2 were cheap and one was not, so don't think I am rich or anything like that.
For 95% of the things I weld I use my Hobart 180 Mig Welder. Good unit for the money, about $550 on sale at TSC with cart, glove, helmet, regulator, ect.
For anything over 3/8" or extremely critical I use my $100 Miller 225 Thunderbolt Stick Welder. Got it from a friend of a friend.
For portability I use a $100 HF gas-less Mig Welder. I have ran this one on my boat many times via a generator and on the dock to fix railings and stuff.
If I had to get one and one only I would get the Hobart 180. Good all around unit.
Chris
   / mig welder preferences #9
I have a Hobart Handler 135 I think it is and recently bought the Handler 210. Also have an old Lincoln AC tombstone box. All have their place. If I could only own one it would be the Handler 210.
The TSC price of $799 right now is a great deal. When I bought my 210 I searched all over and could not find a price that low... I paid around $850 delivered. Locally they were around $900 + tax.
   / mig welder preferences #10
Miller is the welder many pro's and savvy DIY'ers use. They are commonly available at welding supply houses. I can (and did) buy a MIller at one of 4 locations within 30 miles of me, which is the same distance to one of the big box stores (or TSC) where the clerks know what a welder looks like, but no more.
A welding supply store will likely have pricing within 10% or so of the big boxes on Lincoln, which is also a good choice. The supply house is a good source for top quality consumables, safety equipment, and technical information. You won't get that at TSC or the local big box.
Buying a welder at a big box store is similar to buying a lawn mower there. When you need support, you have to go to elsewhere. I won't prostitute myself for the sake of a few bucks. I just bought a Miller Thunderbolt stick welder from a local welding/gas supply house, and I am very happy. It was $4 more than a comparable Lincoln from the same store, and $25 more than the same Lincoln from a Big Box.
2008 HINO 268 ARMORED TRUCK (A45678)
2008 HINO 268...
Kohler Fast Response II 30kW Diesel Generator (A46683)
Kohler Fast...
2019 KENWORTH T880(INOPERABLE) (A48992)
2019 KENWORTH...
Euro Mount Bale Spear (A49251)
Euro Mount Bale...
John Deere Vanburnt Grail Drill (A49251)
John Deere...
Trailer (A46683)
Trailer (A46683)
