MIE 3rd function kit , installed CK2610, getting no pressure to grapple..HELP please
   / MIE 3rd function kit , installed CK2610, getting no pressure to grapple..HELP please #1
jsrore1
Kioti CK2619
ALL,
just installed the kit yesterday getting no hyd pressure to the grapple. when i press the control the LED (red) lights up on the solenoid no hyd oil to the grapple. i can feel it click
other then 2 hoses were cut too short, it seems to be pretty simple set up....remove 2 hoses from the FEL block RED/BLUE connect to there valve, run the 2 hose from the valve back up to the FEL block. then quick disconnect hoses up to the grapple .
then hook up the electrical ....
any suggestions are appreciated...
jeff
just wanted to let every know that COMMON SENSE intervened MIE emailed me back it was all me ...just have to know how to operate the joystick and button at the same time..
works great.....
   / MIE 3rd function kit , installed CK2610, getting no pressure to grapple..HELP please #3
So what was the answer ? Incase it happens to someone else ?
Well it was mostly common sense i assumed you just pulled the trigger "boom" it opens...no ..pull the trigger pull joy stick left or right to open and close...makes sense after thinking about it.
i wish they would have put that in the directions, but i also feel stupid i did not think about it.
i will say the kit was easy to hook up. other then 2 hoses being about 2 inches too short cost me about 60 to get the hoses made.
   / MIE 3rd function kit , installed CK2610, getting no pressure to grapple..HELP please #5
Hmm... I wouldn't think that was a common sense issue. On my Kioti branded third function, I have two buttons to push and they operate independently of the loader control. I wouldn't have thought to move the loader control one way or the other to actuate the third function.
   / MIE 3rd function kit , installed CK2610, getting no pressure to grapple..HELP please #6
2 buttons = solenoid controlled valve, buttons replace control lever
1 on/off button = diverter, selects cylinder to operate
   / MIE 3rd function kit , installed CK2610, getting no pressure to grapple..HELP please #7
That makes sense.
40' CONTAINER (A51244)
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
CURTIS ELECTRIC AIR COMPRESSOR (A51244)
CURTIS ELECTRIC...
BE 3 pt Snow Blower (A50514)
BE 3 pt Snow...
Satoh Beaver Tractor (RUNS) (A50774)
Satoh Beaver...
2018 Ford Ecosport S SUV (A50324)
2018 Ford Ecosport...
