Midwest RB22-60 on a BX2200?
   / Midwest RB22-60 on a BX2200? #1
Anonymous Poster
Epic Contributor
Does anyone have a Midwest RB22 rear blade on a BX2200? I think I would like to have the tilt and especially the offset feature, but I wonder if the BX has enough range of motion for the 3 ph to lift it far enough to be useful? If anyone has one - could you measure how far you can lift it?
Thanks.
   / Midwest RB22-60 on a BX2200? #2
reviving an old thread.... I was wondering the same thing myself. I just got a BX23 and was thinking about putting a rear blade on it. After looking around the RB22-60 seems like one of the best deals out there - tilt , swivel and offset and it is pretty heavy and a pretty good price. Plus if I buy one thru Kioti ( Midwest apparently makes some implements for Kioti) I can get one in orange to match the tractor. So has anybody used any Midwest implements on a BX series tractor? Is the lift capability of the BX 3pt the biggest problem or will I have a problem getting the arms on - will they spread wide enough?
   / Midwest RB22-60 on a BX2200? #3
The RB22-60 sounds similiar to my Woods RB60. The Woods will tilt, swivel and offset. The Woods also has a 15" moldboard, and I can't tilt it on my BX. But I can swivel 360 degrees and offset it.
I think a better choice for the BX is a blade like the Woods RBC60, it has a 12" moldboard and "fits" much better.
   / Midwest RB22-60 on a BX2200? #4
Why can't you tilt it? Does the BX 3pt not raise the blade high enough? Did you have any other problems with using the Woods blade on the BX?
   / Midwest RB22-60 on a BX2200? #5
If I shorten the top link all the way I can get it pretty high but still not high enough to tilt it. I suppose I could drill new holes in the blade but have never gotten around to it.
It works fine for what I use it for. Light snow and since I don't have a boxblade, I use it to grade the driveway.
   / Midwest RB22-60 on a BX2200? #6
I have a Midwest RB22-60 for my bx-22. It's a great blade at a great price. However, I cannot tilt it (one side higher than the other). The first notch puts it at too much of an angle, even with it lifted as high as I can get it. You might be able to save a few bucks and go with the non-tilting version (I think it's an RB20-60).
Kevin
   / Midwest RB22-60 on a BX2200? #7
I ended up buying a Kioti RB22-60 rear blade for my BX23 - I have yet to hook it up to the tractor though. Hope to have the chance to use it next week and will post a report on how it works out. The Kioti RB22-60 is the same blade as the Midwest or the Corriher blade - except that Kioti comes in orange. Plus I found a Kioti dealer in my neck of the woods that had it in stock - I couldn't find anybody near me that carried Midwest so I went with the Kioti.
New Holland 155 Elevator (A49251)
New Holland 155...
6 Tooth Chisel (A49251)
6 Tooth Chisel...
JD 772-A Grader  (A47371)
JD 772-A Grader...
45007 (A48082)
45007 (A48082)
New Holland 479 Haybine (A49251)
New Holland 479...
White 256 Disc (A49251)
White 256 Disc...
