middle buster on box blade
   / middle buster on box blade #1
MESSMAKER
Bluegrass,KY
DK4710SE
I have thought about making a longer middle arm on my box blade instead of buying a separate machine for the few times a year I might need it. The only downside is shear protection. Any Ideas?
   / middle buster on box blade #2
you could make the shaft into 2 peices and put it together side by side. one going up into the boxblade and other going down to the middle buster. put in a 1 shear bolts to hold it in place and other grade 8 to allow it to swing back and not lose the peice.
   / middle buster on box blade #3
Sounds like Radioman has a good idea, I might try it myself.
   / middle buster on box blade #4
I have done that with moderate success.
I made a couple of them using a longer box blade shank. I ripped with the longer stock scarifier first, then put on an even more extended "middle buster" and finally a "furrower" after that. I snapped all of them off except the longer stock scarifier shank. I had to add a "stop block" so when the shank was pushed towards the rear, the stop block hit the blade inside the box blade. It added a tremendous amount of support. Only thing to remember is not to make any turns or the sideways pressure will still snap it off.
I have some photos posted in this thread starting on post #1286.
Making a Boxblade Middle Buster for Trenching
It is in my Log Home and Barn Thread. They have worked well with the added support and not snapped off since I did that. In that thread, I installed all the North lawn irrigation. I just got through installing the South lawn irrigation and I was able to use the furrower without using the other two because the ground was still soft from recent rains. In that thread there are more photos, but here are a couple. The first two photos show the stop I added after breaking the middle buster and furrower. The last two show them before.
Just click on the thumbnails to enlarge.
Rob-
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
UNUSED FUTURE D-PDQ 47" LAND LEVELER (A57193)
UNUSED FUTURE...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A55851)
2025 JMR 36in...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A57192)
2014 MACK ELITE...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
KUBOTA ZD1211 (A53084)
