middle buster/Box blade combo...WHAT???
   / middle buster/Box blade combo...WHAT??? #1
wksinatl
Atlanta
case IH 485
I have a 7' box scrape (King Kutter) and was wondering if I could replace one of the cutters with a much longer/heavier piece of metal to accomodate a 12-14" shovel blade to cut small ditches with?
I could raise (or remove) all of the other cutters and could move the shovel point in any of the other slots. I would have the option of having it dead in the center or to the very edge of the scrape. That way I could get alot closer to a fence without the rear wheels hitting it.
If you see any pros/cons with this idea I would love to hear them.
   / middle buster/Box blade combo...WHAT??? #2
Sounds like a good idea. I seem to remeber a fellow TBNer did it with his box blade. But could not find the thread. /forums/images/graemlins/tongue.gif
   / middle buster/Box blade combo...WHAT??? #3
Should work fine if the spade is welded to something rigid enough. Something else to think about: If you hit a root or rock, there's not much relief. Something will probably snap unless the 23 point hitch rises up.
   / middle buster/Box blade combo...WHAT??? #4
Only issue I see is can you raise your box blade enough for the spade to clear the ground and still have enough length to dig as deep as you want to?
If you are worried about tearing stuff up, you could fashion a shear bolt arrangement. I visualize a single bar going down from the box blade, then welded to two bars (sandwiching the top bar). Then use two bolts for the attaching the lower bar/shovel.
Experimenting with bolt sizes on the lower of the two bolts, you can determine what's a good size. You need it not to shear in hard ground, but shear if you hit a big rock. I'd start with a 3/8" grade five bolt (with 1/2 or larger on the top bolt), the go up to a 1/2" grade 2, if the 3/8" isn't enough, etc.
Shouldn't cost much more and might keep you from starting clear over if/when you hit something.
Best wishes,
ron
   / middle buster/Box blade combo...WHAT??? #5
The best way to do this is to build what you are thinking and then go through a parts manual or through an internet sight to get some ideas. Then try it out in an area that you know is okay. If there are any problems solve them or try a new idea. If it works use it. If you don't want to have problems with your equipment then use a neighbors stuff /forums/images/graemlins/grin.gif
   / middle buster/Box blade combo...WHAT??? #6
I just completed something simaler. Using it in the center keeps the forces in line with the tractor.
I was going to add a small blade to push the spoil further from the ditch.
Kubota RTV-XG850 (A56857)
Kubota RTV-XG850...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A58214)
2013 XLR...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
2008 IC Corporation PB105 School Bus (A55973)
2008 IC...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2014 BRENNER CRUDE TRAILER (A58214)
2014 BRENNER CRUDE...
