Mid size vs full size polaris utv
   / Mid size vs full size polaris utv #11
The 900 is 60" wide. The mid-size 570 is 58" wide and 8" shorter. So the mid-size will be a bit more agile in the woods but there will be very few spots that the 570 will go but not the 900.
You aren't going to sit 3 people in the mid-size.
The mid-size load capacity is half of the full-size.
I would suggest you go to an actual Ranger forum like http://www.prcforum.com/index.php to ask your question.
2" makes a big difference! And also 8" is much longer... This effects steering radius
   / Mid size vs full size polaris utv #12
I run a 4 seat RZR which is big BUT I am amazed where I can take it without any problems. I mostly ride with 2 seat machines and have yet to have a problem. One thing I did is bought a small dump trailer to pull for getting wood and such. Real handy on the tractor also.
Thanks for all you help. I have decided on the 570 polaris for now What options would those of you that have UTV get. I was planning on winch and bumpers but also about bigger tires and a roof
   / Mid size vs full size polaris utv #14
Don't forget the pictures! :thumbsup:
Your usage is different from mine but I wouldn't be without a windshield.
   / Mid size vs full size polaris utv #15
I really like having a Flip Down windshield, but I don't see one offered from Polaris. They do have a Flip Out type, so you might want to take a look at one. Their fixed one is ok for winter, but will be hot in the summer.
   / Mid size vs full size polaris utv #16
If it doesn't already have them get steel CV guards...they are well worth having.
   / Mid size vs full size polaris utv #17
Do what I just did, I bought a 2014 polaris 570 eps crew. Picking her up Friday!
   / Mid size vs full size polaris utv #18
Here is the roof and tilt out glass windshield, on our Polaris Electric.
Doesn't swing out much, but has enough air flow and keeps the bugs off of your face.
Replaced the Carlisle 25-9.5-12, All Trail II, with Interco Interforce 27-7.5-14, 6 ply, 2" narrower, 2" bigger diameter.
The Electric uses the same tire size front and rear. Still have plenty of clearance.
More details here: http://www.tractorbynet.com/forums/atvs-utility-vehicles/287792-electric-polaris-ranger.html
   / Mid size vs full size polaris utv #19
A good set of skid plates!!! The factory ones are THIN and do not offer any real protection. A good set of aftermarket ones, while not cheap, will save the bottom from damage and pay for themselves over time. TUSK makes some very nice ones for a reasonable price.
I also believe A arm guards are a good idea. Nothing worse than a torn CV joint on the trail - not that expensive but a pain and something that can often be avoided.
Good luck and enjoy
Thanks for all your help you guys are awesome
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
2003 INGERSOLL RAND SD-105DX DBL DRUM ROLLER (A52707)
2003 INGERSOLL...
