Mid PTO RPM vs Eng RPM
   / Mid PTO RPM vs Eng RPM #1
mrwitty_1
Ok strange question here but have to ask. I installed a tach on my B7100 just to monitor the rpm. What eng rpm would be used to match the mid and rear PTO speed ? I have a optical tach which I think I could use to measure drive shaft rpm but just wonder if anyone else had figured it out.
   / Mid PTO RPM vs Eng RPM #2
I don't exactly understand the question.
You have the tach installed, and you want to match the mid and rear pto speed to what?
If you mean at what engine rpm is the pto spinning at 540 then information from this website suggests that it is spinning at 540 when the engine is at 2450rpm. I would guess that the mid pto would be the same engine rpm.
Thanks for the reply, I answered my question after looking in my service manual. Everything on this tractor is rated at 2800 engine rpm, the max hp of 13, the rear pto 540 rpm @ 2800, rear pto 850 and also mid pto 2450 @2800.
LMC G300JD LOT NUMBER 246 (A53084)
LMC G300JD LOT...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2005 Mack CV713 Granite Truck, VIN # 1M2AG11C55M020965 (A51572)
2005 Mack CV713...
2020 CATERPILLAR 120 MOTOR GRADER (A51246)
2020 CATERPILLAR...
2017 CATERPILLAR 323FL EXCAVATOR (A51246)
2017 CATERPILLAR...
