Mid PTO lever issues on GC 2410
   / Mid PTO lever issues on GC 2410 #1
Pixguy
Elite Member
By the lake in NH & FL
2011 MF 2410 TLB
Hi Folks, It appears my rear chains were bit to bulky at the overlap connection and has bent up my mid pto lever. It is still operable but the lever doesn't move easily so I control with other lever.
After looking at the Agco parts book, I believe it is part #6254179M91 which is called the Range Lever.
Am I correct in that? The flat straight bar tht went vertical also bent up.
Your advise would be appreciated.
It's possible and more likely as I hunt that it is this lever instead.
#6254748M91
or this one
#6254624M92
I've asked for a quote on the following parts but I'd sure like to hear from one of you GC guys if I have the correct parts as my confidence isn't real high on this issue.
6254188M2 Massey Ferguson ORIGINAL PLATE/I/19X256 1
6254624M92 Agco ORIGINAL PTO LEVER 1
4264970M1 Agco ORIGINAL WASHER 1
3708610M1 Agco ORIGINAL RETAINING RING-1 1
4264958M1 Agco ORIGINAL INSULATOR-120MM 1
6254184M1 Massey Ferguson ORIGINAL GRIP/PTO 1
390972X1 Massey Ferguson ORIGINAL WASHER 2
354043X1 Agco ORIGINAL SPLIT PIN 2
   / Mid PTO lever issues on GC 2410 #4
Not saying what to do, but, can't you just take them off and bend back into shape? You may actually be able to bend them to avoid getting caught by the chains too.
Ok, I did what you suggested and straighten out all the levers. The flat bar was a bit bent but that痴 what good vices are for. Haha.
Overall pleased but will likely replace in the spring. The grip was also a chore and mostly ruined it. Oh well. Back in business.
1DAC5C53-58AF-4AD6-985C-A84C8CA3D796.jpegEAD7A524-AE26-43B1-BD1C-4077FEF8BC37.jpeg6E007AB3-31F2-4883-9A4D-F168DE9BB862.jpeg
   / Mid PTO lever issues on GC 2410 #7
Good job! At least you can use it now, replace later at your leisure.
20306 (A51694)
20306 (A51694)
New 4-235/85R16 Roadguider Trailer Tires (A50774)
New 4-235/85R16...
John Deere 4420 Combine (RUNS) (A50774)
John Deere 4420...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2015 Kia Forte Sedan (A50324)
2015 Kia Forte...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52748)
2018 John Deere...
