Mid-PTO Install...$$$.??
/ Mid-PTO Install...$$$.?? #1
JDGreenGrass
Maine
John Deere 770
Anyone have a ballpark price on installing a mid-pto on JD770.??
Considering this though it is not a priority at this point. Would like a snowblower out front...someday.
/ Mid-PTO Install...$$$.?? #2
I put one on my 770 this past January because I wanted a Mid Mount Mower on it.
First, you have to find one, and that could be the biggest hurdle. It took me over 3 years to find one for mine. JD doesn't make the kit any more, and some of the parts are NLA. I went to both of my local dealers and they said they'd try to locate a NOS kit, or some other dealer with the parts, but neither dealer ever called me back so either they couldn't find the stuff and "forgot" to call or, more likely, I was small potatoes and they just put me at the bottom of their list of things to do. Either way, they never called, never wrote.
So I set up an ebay search and it found one for me this past January. Don't remember exactly but I think I paid about $450 for it. Might have been able to get it for less but I just used the Make an Offer option because I didn't want to risk losing it to another bidder. The seller made a counter offer, we struck a deal, and it arrived with the mail a week or so later.
The kit was complete with everything I needed, in the original box JD shipped it in (though the neutral safety switch was damaged and I've since replaced it with a new one). If you can find the complete kit, grab it.
Since the kits are relatively scarce nowadays, you might just have to pay more than you had planned. I have NO idea what this kit cost when it new and available from JD but the parts price out to over $1500 if bought separately.
So don't give up. I had the ebay search set up for about 9 or 10 months before it struck gold. Or, maybe you have a dealer near you that'll actually work to help you rather than just blowing you off like mine did.
Installation is relatively straightforward; I did it in about 3 hours. See the link below; it's a pretty good indication of what's involved.
http://www.tractorbynet.com/forums/john-deere-owning-operating/28950-790-mid-power-take-off.html
Hope this helps.
dk... Thanks for that post.
450 sounds like a fair price. But, as you say...good luck finding one. Seems I might have read this somewhere before.?
Honestly, I change my mind about the snowblower every other week. I really want to keep the bucket on for the winter which means SB off the back of the tractor. But golly, to have a SB out front...priceless.
/ Mid-PTO Install...$$$.?? #4
I have access to a Mitsibushi 33hp with a 60" Yanmar 3pt SB mounted out front. Two right angle gearboxes from Supply Center send power from rear pto to front. 3 pt was left free to use a rear blade. Much better ground speed selection going forward than low (too slow ), medium (a little too fast ), high ( road gear in reverse ). This tractor has a two speed pto, 540 used most of the time, 1000 when I need to throw farther ( really takes the power ). Being a tall person on a limited sized operating platform, 3 speed ranges, 3 forward gears plus reverse, 2 speed pto, hydralic valves to raise and lower plus rotate chute, electric switch for deflector,and 3pt control for rear blade, keeps me warm in a loose vinyl enclosure. Depending on how much fabricating you can build something simular for $500- $1000.
/ Mid-PTO Install...$$$.?? #5
I believe I have seen one of these for sale in the classified ads here on TBN. Check it out. :thumbsup:
Edit....I just looked....the listing is on page 3 or four....and it fits the 790 which should be the same....no? $200.
2020 PETERBILT 367 (A67714)
2020 PETERBILT 367...
2018 HITACHI ZX470LC-6 EXCAVATOR (A65056)
2018 HITACHI...
1994 GREAT DANE 48' T/A DRY VAN TRAILER (A67714)
1994 GREAT DANE...
2013 TIGERCAT 720E FELLER BUNCHER (A65056)
2013 TIGERCAT 720E...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2018 BOBCAT E26 (A68134)
2018 BOBCAT E26...
