Mowing Mid Mount Mower too High. How do I adjust?
   / Mid Mount Mower too High. How do I adjust? #1
country350
Bronze Member
Michigan
Kioti DK35
I just bought a GC1723 with the drive over mid mount mower. I love the tractor but the mid mount mower wont go low enough. Right now at its lowest setting it is still cutting the grass 8 inches high. I have adjusted the cut height knob to no avail. Any ideas?
   / Mid Mount Mower too High. How do I adjust? #2
I have a 2310 with the "plain" MMM, but I suspect operation's nearly the same. Yes, there is an initial height adjustment, but here's a couple things to check out:
Look in the back to ensure there's nothing preventing the two 3-point hitch (3PH) arms from being able to drop all the way down; the mower drop and the 3PH drop are on the same system. Also check to see that both mower controls are in proper position, both the height adjustment and the drop speed control. (If the drop speed control is totally closed, that will also hold the MMM in the up position.)
Thanks I will check to make sure my 3 point arms aren’t restricted. Both knobs are adjusted correctly; for 3 point lower speed and mower cut height.
   / Mid Mount Mower too High. How do I adjust? #4
I think your tractor has a mower lock in the up position so the three point can be used without the mower going up and down. You can probably find that information in your owners manual. Eight inches sounds about right for the cut height when the mower is in the locked up position on a scut.
   / Mid Mount Mower too High. How do I adjust? #5
If you have the drive-over 2326 MMM, then you have to make a decision: the heavy duty drive over mower is designed to use the caster wheel pin settings as the cutting height adjustment (there is a label with a height guide on the deck) versus the tractor's suspension system. Are your casters set to the tallest configuration? As for the on-tractor adjustment knob: Bring the mower to the FULL UP position, then set to position 1 (lowest/shortest), then lower it down (it should practically touch a level surface IF the casters are retracted).
Both knobs are off of the lock up position. The mower deck raises and lowers. It just doesn’t lower enough to cut low enough.
   / Mid Mount Mower too High. How do I adjust? #7
When attempting to raise and lower mow deck does it actually move? Believe raise/lower of mow deck is similar to 3PH, "hydraulic power" lifts mow deck/3PH and gravity lowers mow deck/3PH, I suggest you verify linkages of mow deck for incorrect latch up or a bind in linkages....
Dale
Yes it moves up and down. It just doesn’t travel down far enough. It travels all the way up when I raise it.
   / Mid Mount Mower too High. How do I adjust? #9
Yes it moves up and down. It just doesn稚 travel down far enough. It travels all the way up when I raise it.
You are absolutely sure the lift lock is disengaged? Even when mine is locked up, it moves about an inch or two when I try and lower it.
Did you try opening the valve for the fall speed a little?
Yep the lift lock is completely off. I am 1,000% sure of that. I will try opening up the lift speed valve some more. The deck does lift and lower about 8 inches or so, so its working. Its just not lowering all the way to the ground.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
2015 Clarke Power Gen 47KW (A50324)
2015 Clarke Power...
2000 JOHN DEERE 310SE BACKHOE (A51242)
2000 JOHN DEERE...
2012 VOLVO A40F OFF ROAD DUMP (A51242)
2012 VOLVO A40F...
Non running toro mower (A48082)
Non running toro...
