Mid Mount Mower on a TC45
   / Mid Mount Mower on a TC45 #1
Vinto
What is a mid mount worth including the cost of the mid PTO. 72" model?
   / Mid Mount Mower on a TC45 #2
I am not sure about the mid PTO. But I paid around 2,500 for my 72" 914 New Holland Mid Mount. But with the size of your tractor why would you want the 72". To me your tractor should handle the 84" with no trouble. I have the 72" on my TC29D with Gator Blades. Unless you have to have the side discharge.
murph
   / Mid Mount Mower on a TC45 #3
Depending on what model year TC-45, the tractor may or may not be available with a mid pto. However, last year when I almost went the mid mower set up on my TC-40D, the mid PTO kit was $550 and the 84" mmm with rear discharge was $4,000. The only reason I did not go this route was that the mid mount mower brackets and the backhoe subframe mounts were not compatible. Hope this helps. (New England Pricing)
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
2020 COLOMBO TM LOT NUMBER 194 (A53084)
2020 COLOMBO TM...
Valvoline 80//90 Gear Oil (A53117)
Valvoline 80//90...
