Mowing Mid Mount Mower Belt
   / Mid Mount Mower Belt #1
Skip G
Cheshire, Oregon
Kubota BX2200
Hi all
Have a 60" MMM for my BX2200. Removed and serviced it for winter storage.
According to the manual, the belt should be loosened for winter storage.
Is this necessary ?
Another dumb question...
What's the best way to remove it?
I tried for a few minutes, but couldn't seem to get the idler pulley to move to get the slack necessary.
   / Mid Mount Mower Belt #2
Look for that magic spring that puts tension on the idler pully
Jim
Thanks, yes saw the spring. I guess just remove one end ?
   / Mid Mount Mower Belt #4
Remember this! That spring has lots of tension on it and make a drawing before you take it apart.
Jim
   / Mid Mount Mower Belt #5
What I do is pull up on the belt on the pully as I am slowly turn it and walk it off the pully. I then repeat the same process in the spring. The spring has a lot of tension and can do some damage, so BE CAREFULL, wear gloves and and safety glasses. Same belt since 2002!:eek:
   / Mid Mount Mower Belt #6
Guess I need to do something--I haven't taken my MMM belt off since 2003 when it was new, or loosened the belt............
ron
   / Mid Mount Mower Belt #7
I did not remove my belt last year but was thinking about it this year. I'm sure Kubota is really proud of those belts.
   / Mid Mount Mower Belt #9
Just took my deck off tonight for the first time, in prep for winter. Haven't taken the belt off but plan to ease the tension on it. I wish the deck on my old Toro came off as easy as the Kubota.
   / Mid Mount Mower Belt #10
I can't remember *exactly* how I do it, but I found I could use some part on the deck as a fulcrum and pry against the pulley arm to unload the belt pretty easy. Have slipped it on/off the last couple of winters no problem. We're still mowing down here...
Russell in Texas
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
JOHN DEERE LOT NUMBER 138 (A53084)
JOHN DEERE LOT...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
