Mowing Mid Mount Mower Belt
   / Mid Mount Mower Belt #1
Skip G
Cheshire, Oregon
Kubota BX2200
Hi all
Have a 60" MMM for my BX2200. Removed and serviced it for winter storage.
According to the manual, the belt should be loosened for winter storage.
Is this necessary ?
Another dumb question...
What's the best way to remove it?
I tried for a few minutes, but couldn't seem to get the idler pulley to move to get the slack necessary.
   / Mid Mount Mower Belt #2
Look for that magic spring that puts tension on the idler pully
Jim
Thanks, yes saw the spring. I guess just remove one end ?
   / Mid Mount Mower Belt #4
Remember this! That spring has lots of tension on it and make a drawing before you take it apart.
Jim
   / Mid Mount Mower Belt #5
What I do is pull up on the belt on the pully as I am slowly turn it and walk it off the pully. I then repeat the same process in the spring. The spring has a lot of tension and can do some damage, so BE CAREFULL, wear gloves and and safety glasses. Same belt since 2002!:eek:
   / Mid Mount Mower Belt #6
Guess I need to do something--I haven't taken my MMM belt off since 2003 when it was new, or loosened the belt............
ron
   / Mid Mount Mower Belt #7
I did not remove my belt last year but was thinking about it this year. I'm sure Kubota is really proud of those belts.
   / Mid Mount Mower Belt #9
Just took my deck off tonight for the first time, in prep for winter. Haven't taken the belt off but plan to ease the tension on it. I wish the deck on my old Toro came off as easy as the Kubota.
   / Mid Mount Mower Belt #10
I can't remember *exactly* how I do it, but I found I could use some part on the deck as a fulcrum and pry against the pulley arm to unload the belt pretty easy. Have slipped it on/off the last couple of winters no problem. We're still mowing down here...
Russell in Texas
2020 INTERNATIONAL LT625 DAY CAB (A52576)
2020 INTERNATIONAL...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2012 JOHN DEERE 410K BACKHOE (A51406)
2012 JOHN DEERE...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
2012 PETERBILT 587 SLEEPER (A52577)
2012 PETERBILT 587...
2000 FORD E350 CUTAWAY BOX TRUCK (A52577)
2000 FORD E350...
