Mid eighties L4150 return circuit woes
   / Mid eighties L4150 return circuit woes #1
J K S
Kubota
Greetings to all,
Hope someone might be able to help.
I've got brake lining material clogging the return circuit after the filter in the tranny filter boss return port located directly under the center filter port. Has this issue before and cleaning out what I could with a change of filter as well solved the problem for a while. Now the only way I can get a little flow is after wiggling a wire around in the port to dislodge some of the crud and allow some fluid to pass. My question is does anyone know a trick or three to unclog that area of foreign material without splitting the machine? I already tried pressurizing the tranny case a bit with no results, I wonder if there is a specific fitting somewhere on the tranny I can grab onto with either air or fluid to force the stuff back out. Any and all suggestions would be greatly appreciated.
Thanks in advance!!
JKS
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
2015 GATORMADE 45' - 10 TON GOOSENECK TRAILER (A52708)
2015 GATORMADE 45'...
JOHN DEERE 6500 HI-CYCLE SPRAYER (A52708)
JOHN DEERE 6500...
1754 (A58375)
1754 (A58375)
Terms & Conditions of (Buying through EquipmentDealz Auction) Continued (A59213)
Terms & Conditions...
