Micrometer
   / Micrometer #11
I googled GAT St Louis Mo. and it came back with a manufacturing company called General Automatic Transfer, just outside of St Louis, might be a clue or somewhere to start.
   / Micrometer #12
Stepdad was the head mechanic for a small municipality. I remember my mom's chagrin as he was frequently called out at all hours to fix police, fire, and street dept vehicles. He liked what he did though!
This curious 0"-0.5" micrometer will just be hung on a wall as a conversation piece. It's not even comfortable to hold to get a measurement! Basically, I was just wondering why something this small would even exist! Again, I'm thinking it was a novelty piece.
It would be handy to keep in your pocket if you had to measure gauge stock, angle iron thickness, or feeler gauge stock on a routine basis. Typically, there would be a small hole in the barrel where a wrench would spin the barrel to align it back to zero when fully closed.
Sounds like a good piece to save as a keepsake.
   / Micrometer #13
Guessing it’s off 1 graduation which would be .001”. That’s still alot for a micrometer. Make sure there is nothing on the measuring faces of the tool. Old trick is to lightly close it on a piece of paper and drag the paper out to clean the measuring faces. If it’s still off, the graduated barrel can be rotated to bring it into spec. There should be a small hole on the barrel for a spanner wrench. Most micrometers come with the correct spanner wrench for adjustment.
   / Micrometer #14
I am going to bet you a big fat steak (or gallon of gas) you are on the wrong track.
GAT is not the maker of the tool.... it is the business that used/owned the tool. Stamped their initials and factory location to prevent theft/loss.
I have a very similar tool we used in the 50's and 60's to mic out flat stock and structural steels used in manufacturing. Highly expensive back in the day, coveted, and prized versus today where every Tom/Dick and Harry has tools like this in their loading rooms, shops, tool boxes, etc...
Was your Stepdad a welder/fabricator/engineer?
A History of Forward Thinking, Satisfied Clients and Long-Term Employees
Born out of engineering expertise and passion for efficient design, GAT was founded by the current owner’s grandfather in 1958 in St. Louis, Missouri. From the beginning, we put our focus on creating custom finishing solutions and process lines for companies in North America. GAT was at the forefront of industry change in the 1960s, innovating and creating patented technology and processes. We’ve always had a strong focus on family and our employees, which is why people come to work for GAT and stay here for many years.
I bet you are correct.
   / Micrometer #15
Found this in Stepdads tool box while going through things to have an estate sale.
Anyone heard of GAT? My first thought is that this was a novelty item. It is 0" to 0.5". Seems to be off 0.1" over full range. There is a screw on the end that might allow adjustment, but the barrel rotation is not smooth and needs cleaning.
Based on the fact that stepdad retired in the early 80's, I'm guessing this is something from the 60's or 70's.
   / Micrometer #17
Clark Gable refers to a handgun as a "gat" in It Happened One Night".
   / Micrometer
I unscrewed the thimble from the sleeve and removed the screw on the end of the thimble. This allowed the spindle to be removed from the thimble. Bad news. The spindle was threaded into the sleeve and the screw acted at a lock for puposes of calibration. The threads on the spindle that screwed into the thimble are bad. Threads on the spindle for turning the thimble in and out to take a measurement are fine.
Bottom line, this little micrometer can't reliably be calibrated anymore. Definitely just a conversation piece at this point.
   / Micrometer #19
Smaller mics were generally used to measure tubing wall thickness or sheet metal gage thickness. Is the fixed anvil rounded?
   / Micrometer
No. It's not a quality piece. As I've said before, It's pretty much a novelty item or something a salesman handed out at Christmas.
The discussion has been fun though! And for me, the family connection is worth putting it on my tool board in the shop to talk about.
2012 Cadillac SRX SUV (A55853)
2012 Cadillac SRX...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
1618 (A57192)
1618 (A57192)
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
