MH Pony Wiring
/ MH Pony Wiring #1
looch
QC, Canada
CK2620 SE Cab
I recently acquired a 1951 Massey Harris Pony. It was running, but the wiring was scary - cracked insulation, fraying at the terminals, etc. I bought a new harness which came with a basic "connect A to B" instruction list. I compared it to the shop manual's wiring diagram, and they match. Here's the shop diagram:
A previous owner had replaced the generator/light switch with a 3-position light switch. This meant having to do something with generator's F terminal (blue wire). Simple solution (though not ideal) - routed to a grounded switch. So this switch is performing lighting duty only.
My confusion lies around the starter button. I can't make sense of the diagram - it has the starter and ammeter/battery connected to the same terminal on the factory 3-position switch. Press the starter button, all you do is create a loop through the negative side of the circuit i.e. nothing happens. In order for the starter button to engage the starter solenoid, it needs to complete a circuit through ground. To me, then, that means that the factory 3-position switch must have continuity from ground to the terminal onto which the starter is connected. But if that were true, the battery would be in a constant short circuit as the ammeter/battery shows as being connected to that same terminal.
Is the shop diagram messed up? Am I? For reference (and for my own sanity) I photocopied, whited out, and re-drew the wiring diagram to correspond to the "as-bought" condition:
UNUSED WOLVERINE TDB-11-84W-84" BUCKET (A64281)
UNUSED WOLVERINE...
(10) John Deere Tractor Weights (A64119)
(10) John Deere...
2012 Toyota Tundra SR5 Crew Cab Pickup Truck (A61573)
2012 Toyota Tundra...
2006 MINI Cooper Convertible Coupe (A61574)
2006 MINI Cooper...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
