MFWD U-Joint Zerks missing?
/ MFWD U-Joint Zerks missing? #1
Rmiked
Fort Mill, SC
John Deere 5065e, 2013
I have a 2013 5065E, 4WD. The MFWD axle has no zerks on the U-joints . Are these sealed and permanently lubricated? How long will the U-Joints last without lubrication ability? Thanks
/ MFWD U-Joint Zerks missing? #2
They may very well be “ sealed/lubricated for life ” u joint. Did you check your owners manual? I suggest you get ahold of one if you haven’t already.
They should last a long time, but that depends on the service use by you. Things like excessive use in 4WD, submerging in water, loader use, tight turns affect their life.
The owners manual only depicts zerks on the 2WD front axle. For the MFWD axle it only references the 2 zerks on front and rear of pivot pin. Additional lubrication is the oil in the axle itself and separately in the hubs.
/ MFWD U-Joint Zerks missing? #4
My 4105 (purchased 2013) Owner Manual indicated grease nipples on the front axle also, it drove me mad trying to locate them until I asked my Dealership where they were. Turns out that they were replaced by sealed units... the manual hadn't been 'updated'. They also showed me the grease nipples underneath the FWD/REV pedals that had been added but, again, not included in the Owner Manual.
To be positive, visit or ring your local JD Dealership's Parts Department to confirm.
/ MFWD U-Joint Zerks missing? #5
Well, there you are.
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2005 Butler pole trailer (A62679)
2005 Butler pole...
APPROX. 2000 GALLON FUEL TANK (A63291)
APPROX. 2000...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
