MFWD U-Joint Zerks missing?
   / MFWD U-Joint Zerks missing? #1
Rmiked
Fort Mill, SC
John Deere 5065e, 2013
I have a 2013 5065E, 4WD. The MFWD axle has no zerks on the U-joints . Are these sealed and permanently lubricated? How long will the U-Joints last without lubrication ability? Thanks
   / MFWD U-Joint Zerks missing? #2
They may very well be “ sealed/lubricated for life ” u joint. Did you check your owners manual? I suggest you get ahold of one if you haven’t already.
They should last a long time, but that depends on the service use by you. Things like excessive use in 4WD, submerging in water, loader use, tight turns affect their life.
The owners manual only depicts zerks on the 2WD front axle. For the MFWD axle it only references the 2 zerks on front and rear of pivot pin. Additional lubrication is the oil in the axle itself and separately in the hubs.
   / MFWD U-Joint Zerks missing? #4
My 4105 (purchased 2013) Owner Manual indicated grease nipples on the front axle also, it drove me mad trying to locate them until I asked my Dealership where they were. Turns out that they were replaced by sealed units... the manual hadn't been 'updated'. They also showed me the grease nipples underneath the FWD/REV pedals that had been added but, again, not included in the Owner Manual.
To be positive, visit or ring your local JD Dealership's Parts Department to confirm.
   / MFWD U-Joint Zerks missing? #5
Well, there you are.
2019 Ford F-350 4x4 Crew Cab AutoCrane EHCPRX 3,200lb 1.5 Ton Crane Mechanics Truck (A50323)
2019 Ford F-350...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A51572)
2007 Isuzu FTR...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
2020 Lincoln Naultilus SUV (A50324)
2020 Lincoln...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
